linux Error page
- jfrahm3310
30 Dec 2020 23:14 #193591
by jfrahm3310
linux Error page was created by jfrahm3310
So this may be just a new to Linux problem but how do you copy or print the Linux error page when first starting up or is there a file somewhere else.
30 Dec 2020 23:38 - 30 Dec 2020 23:40 #193594
by chris@cnc
Replied by chris@cnc on topic linux Error page
Hi
- Screenshot
- file in /tmp/linuxcnc_info.txt
- or select with the mouse and then press the mouse wheel to insert. and write it as a spoiler or code so that the formatting is retained.
The debug information is very good. In the lower part,
Debug file information:
Note: Using POSIX realtime
The error is always described and Google will find it.
Last edit: 30 Dec 2020 23:40 by chris@cnc.
31 Dec 2020 10:44 #193626
Replied by rodw on topic linux Error page
The easier way is just start linuxcnc in a terminal window by typing linuxcnc. Any errors will be printed in the terminal window and you can copy and paste to a text editor so you want to ask for help here.
I often type linuxcnc -l to run the last config I ran.
The following user(s) said Thank You: ikkuh
Time to create page: 0.154 seconds
