Using M64 command for a relay trigger
04 Jan 2021 19:12 #194063
by Hamel2020
Replied by Hamel2020 on topic Using M64 command for a relay trigger
Yes , you are right .. Now the problem is solved ...
Thank you Peter .
Thank you Tom .
I have one more question :
Is it possible to supply the sinking signal from (DO) with a voltage less than 24V , like 12V or 5V ?
Thank you Peter .
Thank you Tom .
04 Jan 2021 23:38 #194091
Replied by PCW on topic Using M64 command for a relay trigger
Yes
Time to create page: 0.200 seconds
