motor scale
09 Jan 2021 13:35 #194589
by Yannis
motor scale was created by Yannis
Hello
i need help for the scale of my motors
i use dmm dyn 4 driversand this encoder
www.dmm-tech.com/abs16encoder_main.html
in Z axis i have motor pulley with z24 to z72 and ballscrew with 5mm pitch
in Y axis motor pulley z24 to z 36 and rack and pinion with z24
in X axis i have 1/10 reduction and ballscrew with 10mm pitch
and in C axis i have 1/91 reduction and some gears that is not possible to count the z (teeth)
- Thank you received: 5946
09 Jan 2021 16:27 #194607
Replied by tommylight on topic motor scale
Use the wizards and enter the above info, they will sort the scaling.
Just a heads up, the rack and pinion need more info, like pitch and module, not just teeth.
The following user(s) said Thank You: Yannis
Time to create page: 0.133 seconds
