Radius differs error
17 Jan 2021 20:45 - 17 Jan 2021 20:46 #195701
by Jabbery
Radius differs error was created by Jabbery
Hello,
Ouch, day 1 of finally being able to run a linuxcnc test and both F360 and Vcarve desktop gcode produces:
Radius to end of arc differs from radius to start
or
Arc Radius too small to reach end point.
I read posts that talk about this with suggestions, I tried all the suggestions I could find and nothing changed the problem. If I set radius arcs to NO and turn off helix I get the too small error from the differs error no matter what I set in the ini file for tolerance.
Suggestions?
or
Suggestions?
Last edit: 17 Jan 2021 20:46 by Jabbery.
17 Jan 2021 23:51 #195723
by Jabbery
Replied by Jabbery on topic Radius differs error
SOLVED. And they say your insane if you attempt a solution the same over and over expecting different results!
Time to create page: 0.069 seconds
