linuxcnc included in iso
19 Jan 2021 18:46 - 19 Jan 2021 18:49 #195910
by bevins
linuxcnc included in iso was created by bevins
Is there a linuxcnc with rt kernel iso linuxmint?
I cant find the linuxmint one, the link was removed.
Last edit: 19 Jan 2021 18:49 by bevins.
- Thank you received: 5951
19 Jan 2021 21:15 #195918
Replied by tommylight on topic linuxcnc included in iso
It was here but apparently it is not any more:
forum.linuxcnc.org/9-installing-linuxcnc...int-19-3-iso?start=0
Try this for 19.3:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Or this for 20
forum.linuxcnc.org/9-installing-linuxcnc...-nearly-easy-install
Be aware that if you intend to use QT-anything, use the 19.3 as 20 will not work (or it will after several hours of chasing gremlins). And 19.3 takes about 20 minutes in total besides downloading the ISO. Took under 4 minutes on a new Ryzen PC !
Try this for 19.3:
Or this for 20
