Enable/disable backlash/screw compensation via G-Code (or hal)?
- underscore
- Topic Author
20 Jan 2021 04:17 #195971
by underscore
Is it possible to temporarily enable or disable the backlash compensation via GCode or HAL? I would like to only use backlash compensation for finishing passes and drill, for example.
20 Jan 2021 13:37 - 20 Jan 2021 18:26 #195989
Replied by Aciera on topic Enable/disable backlash/screw compensation via G-Code (or hal)?
You should be able to access your backlash value through the hal-pin 'halui.0.backlash' 'ini.0.backlash'. So try to connect that to the output of a mux2 with one input set to your joints backlash value and the other input set to zero. Then you can use say 'motion.digital-out-00' as your input selector on the mux2.
That should make it possible to set backlash the nonzero value using :
Or to zero using:I'm not sure if you need both queue busters (M66 E0 L0). But it won't hurt to use one before and one after switching the backlash value. If it's too much of a hassle to code this every time in the Gcode you could pack those three lines in a M-code remap.
M66 E0 L0 ; force synch
M64 P0 ; set motion.digital-out-00
Or to zero using:
M65 P0 ; reset motion.digital-out-00
Last edit: 20 Jan 2021 18:26 by Aciera. Reason: got the pin wrong
The following user(s) said Thank You: underscore
- underscore
- Topic Author
20 Jan 2021 15:19 #195998
by underscore
Replied by underscore on topic Enable/disable backlash/screw compensation via G-Code (or hal)?
Thanks for the quick reply. Where do I find information about that halui pin? I can’t seem to locate it in linuxcnc.org/docs/devel/html/man/man1/halui.1.html
20 Jan 2021 18:25 - 20 Jan 2021 18:31 #196011
I'm sorry it's 'ini.0.backlash'.
[edit]
found something here:
linuxcnc.org/docs/html/man/man1/milltask.1.html
[edit]
Last edit: 20 Jan 2021 18:31 by Aciera.
- underscore
- Topic Author
21 Jan 2021 02:04 #196049
by underscore
Wow, I didn't know it was possible to overwrite the ini values from hal. Very useful! Thanks so much!
- underscore
- Topic Author
24 Jan 2021 03:22 #196376
by underscore
My solution: ("g62.ngc"):
o<g62> sub
(Enable backlash compensation on X and Y)
(add to *.ini: REMAP=G62 modalgroup=1 argspec=P ngc=g62)
(Requirements:)
(In postgui.hal)
(net x-backlash <= motion.analog-out-00 => ini.0.backlash)
(net y-backlash <= motion.analog-out-01 => ini.1.backlash)
(Recommended to add G62 P0 to the startup and abort.)
o50 if [#<P> EQ 1]
o100 if [EXISTS[#<_ini[joint_0]backlash>]]
M68 E0 Q[#<_ini[joint_0]backlash>]
o100 else
(DEBUG, No backlash set in the ini file for JOINT_0)
o100 endif
o200 if [EXISTS[#<_ini[joint_1]backlash>]]
M68 E1 Q[#<_ini[joint_1]backlash>]
o200 else
(DEBUG, No backlash set in the ini file for JOINT_1)
o200 endif
(PRINT, Backlash compensation enabled.)
o50 elseif [#<P> EQ 0]
M68 E0 Q0
M68 E1 Q0
o50 endif
M66 E0 L0 (Queue buster)
o<g62> endsub [1]
M2
Time to create page: 0.121 seconds
