5-axis TCP / RTCP setting
21 Jan 2021 19:49 #196140
by JackRay
5-axis TCP / RTCP setting was created by JackRay
Hello,
I am looking for a method, a calculation to set my TCP / RTCP exactly and precisely. Can anyone help me .
Thanks for your help
21 Jan 2021 20:30 #196144
by scotth
Replied by scotth on topic 5-axis TCP / RTCP setting
Renishaw Axiset software works well for this. But there is no LinuxCNC support. They probe a sphere around the b rotation and measure error of calculated point to actual point. Than they use the same setup to track the sphere through the arc. This should give you the true centers compared to calculated centers. It is fast and accurate.
The following user(s) said Thank You: JackRay
Time to create page: 0.177 seconds
