Homing, can't figure it out.
27 Jan 2021 10:19 #196728
by SPH
Homing, can't figure it out. was created by SPH
Thanks to those who offered some suggestions on the facebook group.
I'm not having much luck getting my home switches working. I've likely got something simple set wrong, would appreciate if someone could take a look at my files and offer some suggestions.
XY and Z switches are connected and show in HAL config, both under the 7i77 input pins and the home switch section. Light up when triggered as I would expect they should.
When I hit the home all button the axis I have set as 0 heads off looking for the switch but doesn't do anything when it's triggered. The axis just keeps on trucking until it hits the limit switch. Limit switches aren't connected to the 7i77, just the drives.
27 Jan 2021 11:25 #196744
by Clive S
Replied by Clive S on topic Homing, can't figure it out.
try this:
Change
net x-home-sw => joint.0.home-sw-in
to
to net x-home => joint.0.home-sw-in
Check what the names of the pins in the hal show
Change
to
27 Jan 2021 21:36 #196825
by SPH
Replied by SPH on topic Homing, can't figure it out.
Thank you, that was it. Correct format was home-x, y, z. Can't believe I was staring at the answer the whole time. I must have checked those input names against each other 5 times and never picked up that they were different.
27 Jan 2021 22:33 #196832
by Clive S
As Tom always says you're welcome.
Glad you got it sorted
28 Jan 2021 00:01 #196858
I didn't even know that there _was_ a Facebook group.
Replied by andypugh on topic Homing, can't figure it out.
29 Jan 2021 21:13 #197089
by bevins
www.facebook.com/groups/465128047350433
Replied by bevins on topic Homing, can't figure it out.
31 Jan 2021 00:11 #197186
Oh, I found it. But it is a real effort to get through all the forum and mailing lists. Adding Facebook (and Discord?) would leave me no time to eat or sleep.
Time to create page: 0.138 seconds
