No 7i92 board found
28 Jan 2021 14:01 - 29 Jan 2021 12:28 #196939
by bevins
No 7i92 board found (SOLVED) Operator error was created by bevins
mesaflash downloaded and compiled from github and it cant find my 7i92.
It says No 7i92 found. I can ping it so I know it is there. 5v is connected also.
Is there a document for mesaflash? I need to understand why I have a hard time everything I try to use mesaflash. sometimes it works some times it does not.
Last edit: 29 Jan 2021 12:28 by bevins.
28 Jan 2021 14:11 - 28 Jan 2021 14:25 #196940
by bevins
Replied by bevins on topic No 7i92 board found
linuxcnc starts and I/O is working.
Mesaflash cant find the 7i92. I need to flash it with 7i77 and 7i74 firmware
Is it called another name?
I had the same issue a few weeks ago onsite at a customers place.
Last edit: 28 Jan 2021 14:25 by bevins.
28 Jan 2021 14:47 - 28 Jan 2021 15:00 #196943
by bevins
ok I figured it out. Very frustrating with no manual on mesaflash.
For some reason if you have it set to 192.168.1.121 it will work but 10.10.10.10 you need to add the --addr
Is there a way to check which bit file is loaded without having card attached?
OK I got it figured out.
Last edit: 28 Jan 2021 15:00 by bevins.
28 Jan 2021 23:53 #197001
Feel like writing one?
Replied by andypugh on topic No 7i92 board found
29 Jan 2021 01:52 #197024
Replied by PCW on topic No 7i92 board found
Did you try mesaflash --help?
29 Jan 2021 07:03 #197037
by Michael
The 7i92 manual has a terminal line to verify the installed flash. If you know what bit file you are looking for you can confirm it is there and will need to add the --addr line if it's not the 192.168.1.121
Replied by Michael on topic No 7i92 board found
29 Jan 2021 12:10 #197046
by bevins
Sorry guys, I didn't mean to be disrespectful. It didn't come out the way I meant it to. I really appreciate all the help and the efforts you all put in.
Everything is working. I just cannot find out how to tell what bit file is loaded.
- Thank you received: 5933
29 Jan 2021 12:40 #197052
Replied by tommylight on topic No 7i92 board found
Most probably you already have the downloaded files for the 7i92 from mesa, there are bit files and pin files for most configs, so do a readhmid and open the pin files to check the pinout.
I never bother to find out what is already there, chances are it will not fit what i need, so i just flash what i need and move on.
The following user(s) said Thank You: bevins
29 Jan 2021 13:04 #197055
by bevins
I can try. I may brick a couple boards along the way....
Time to create page: 0.152 seconds
