Changing INI JOINT SCALE online
- Thank you received: 5246
01 Feb 2021 21:20 - 02 Feb 2021 01:13 #197335
Replied by PCW on topic Changing INI JOINT SCALE online
Sure, you are just commanding velocities so all positioning is relative
Last edit: 02 Feb 2021 01:13 by PCW.
02 Feb 2021 01:13 - 02 Feb 2021 01:19 #197365
I should mention that changing to open loop if you have a standard
PID stepgen configuration would be as simple as setting the P gain to 0,
and looping LinuxCNCs commanded joint position back to
LinuxCNCs joint feedback position.
Last edit: 02 Feb 2021 01:19 by PCW.
- AlessandroT
- Thank you received: 4
02 Feb 2021 05:16 #197374
by AlessandroT
Replied by AlessandroT on topic Changing INI JOINT SCALE online
Thanks to your feedback i tried to re-wiring like that, but I guess I am still missing something, because using gmocappy I can't see the A values increasing if I jog the A axis ( and after a while the following error appears again
Maybe I forgot to set somewhere that I will use the velocity mode to the A axis?
net emcmot.03.vel-cmd <= joint.3.vel-cmd
net emcmot.03.vel-cmd => pid.6.command
net motor.03.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-fb
net motor.03.pos-fb => joint.3.motor-pos-fb
net motor.03.pos-fb => pid.6.feedback
net motor.03.command <= pid.6.output
net motor.03.command => hm2_[HOSTMOT2](BOARD).0.stepgen.03.velocity-cmd
setp pid.6.enable 1
setp pid.6.enable 1
02 Feb 2021 06:25 - 02 Feb 2021 06:36 #197378
Note that the PID 6 P term must be 0
Also using the PID allows a sneaky way to do the scaling by varying the FF1 term pin
and possibly things like FF2 may be useful for an extruder
Or if you dont want to use a PID at all, just
But this still needs the scaling added
net motor.03.loopback <= joint.3.motor-pos-command ## note command is looped back to feedback
net motor.03.loopback => joint.3.motor-pos-fb ## so no following errors are possible
net motor.03.loopback => pid.6.command ## PID gets its position command from the joint command
net extruder_velocity <= pid.6.output
net extruder_velocity => hm2_[HOSTMOT2](BOARD).0.stepgen.03.velocity-cmd
setp pid.6.enable 1Note that the PID 6 P term must be 0
net emcmot.03.vel-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.03.velocity-cmd
Last edit: 02 Feb 2021 06:36 by PCW.
- AlessandroT
02 Feb 2021 18:21 #197460
by AlessandroT
Finally it works!! thanks to your help
I didn't have any pid before so I tried the direct link between commanded and feedback position. I tried also with PID but probably I need to tune other parameters because it didn't work well as the direct link did, that is my preferred option.
I prefer to not add any scale component (that can run only with a servo thread ) because I'd like to only adjust the parameter "hm2_7i76e.0.stepgen.03.position-scale" that exist yet.
Roughly i can modify it through "halcmd step", but i want to find a more elegant way through a gmocappy widget.
The new question now is, how can I wire a parameter? Or how can I modify a parameter from a GUI ?Is it possible? We will end this process:)
02 Feb 2021 18:25 - 02 Feb 2021 18:32 #197461
You cannot wire a parameter hence the need for the scale component
(Or PID component with its FF1 pin wired to your adjustment pin)
That is, if you use the PID component connected as shown in my first example
(and all terms 0 except FF1), if the PIDs FF1 pin is 1.0 it will behave the same
as connecting the joint velocity to the stepgen velocity pin, except that you can
now wire the PID FF1 pin to your variable extruder scale source.
Last edit: 02 Feb 2021 18:32 by PCW.
- AlessandroT
02 Feb 2021 21:58 #197482
by AlessandroT
Yes, it will be the best solution! I tried and it works. The only limit is the pid connection to the servo thread instead of the base one. It can affect the stepgen generation somehow?
02 Feb 2021 22:25 #197486
You dont need a base thread with Mesa hardware
Time to create page: 0.117 seconds
