Coordinate system - Running from a program line problem.
- AlessandroT
- Thank you received: 4
31 Jan 2021 20:03 - 31 Jan 2021 21:34 #197243
by AlessandroT
Sorry for the newbie question, but i get always this problem and I want to know how to avoid it.
Example:
My machine is setted up with 5 axis.
I'm running a program. For some reasons I get a stop to the machine and I want to start again the program from a line where it was interrupted.
If my A axis was at position 312500 in that line, I try to write "g92 A 312500" or a bit less than this.
When I run the program from that line, the A axis skip very fast over 312500 and continue to increase ( I don't know in which coordinates world is setted the target value If it's 312500 ) generating a following error, and I can't start the program.
Any suggestions to solve it, please?
Example:
Last edit: 31 Jan 2021 21:34 by AlessandroT.
02 Feb 2021 00:14 #197353
Replied by andypugh on topic Coordinate system - Running from a program line problem.
What does the line that you are starting from say in this example?
You could try touch-off in the GUI (which used G10) to set the A axis position, but I am very unclear on why that is needed.
- AlessandroT
02 Feb 2021 05:25 #197375
by AlessandroT
Replied by AlessandroT on topic Coordinate system - Running from a program line problem.
In this example, I was 3d printing and the A axis is my extruder. I tried to scale the output of the extruder "online" because it was over extruding, but when I did it, I got a "following error" and the program ended. Normally I could restart the print from that line, but if I try to do it, the A axis increase in a crazy and not understandable way by me destroying the print.
As this event of interrupt and restart a print from the middle happens many times for different reasons, I want to understand how to solve this A axis problem.
Any help to understand what happen in the software will be very helpful
02 Feb 2021 08:28 #197389
I don't really understand the problem.
Are you restarting completely, so that the A axis is returned to zero?
Normally:
(moves)
G1 Xxxx Yyyy A1000
(stop machine, A = 1000, move X Y Z, return, A=1000 still)
(run from line)
G1 Xxxx Yyyyy A1010
Would only be a move of 10 units in A.
If the A axis is not in the same postition as the move before the run-from-line then I think that you should be able to use "touch-off" in the GUI to set A to the right number.
But I would also expect G92 to work too.
Normally:
(moves)
G1 Xxxx Yyyy A1000
(run from line)
G1 Xxxx Yyyyy A1010
- AlessandroT
02 Feb 2021 08:48 #197391
by AlessandroT
I usually set the G92 A1000 value or the A value identical as the line of the Gcode where I will start the program, but The A axis increase in a crazy and not controlled way over that value without stopping it.
Reality:
(moves)
G1 Xxxx Yyyy A1000
(run from line)
G1 Xxxx Yyyyy A1010
A axis, didn't stop to increase till I push the emergency button.
Today I will try the "touch off" if it will make any difference. But anyway I would like to understand why it happen like that.
Reality:
(moves)
G1 Xxxx Yyyy A1000
(run from line)
G1 Xxxx Yyyyy A1010
02 Feb 2021 08:58 #197394
Is A configured in the INI as a WRAPPED_ROTARY?
- AlessandroT
02 Feb 2021 09:01 #197395
by AlessandroT
No is it a LINEAR TYPE.
[JOINT_3]
TYPE = LINEAR
MAX_VELOCITY = 2500
MAX_ACCELERATION = 1500.0
# Set Stepgen max 20% higher than the axis
STEPGEN_MAX_VEL = 3000.0
STEPGEN_MAX_ACC = 2000.0
[JOINT_3]
TYPE = LINEAR
MAX_VELOCITY = 2500
- Online
- Thank you received: 5932
02 Feb 2021 10:27 #197405
Replied by tommylight on topic Coordinate system - Running from a program line problem.
For the extruder you need to set the stepgen to velocity mode, not position mode.
02 Feb 2021 13:18 #197420
That (probably) only works if the G-code is set up for it. And even then I don't know how it would work for retracts.
- Online
02 Feb 2021 13:32 #197425
But how to use it is for now unclear to me, but i would assume something similar to a spindle... a bit fuzzy on all this.
Direction should work in velocity mode, or?
