G64 P and Q
the same as
G64 P0.001 Q0.00 ?
and Q0.00 is the same as no Q ?
I think the documentation suggests this but it's not stated explicitly.
I haven't been using Q, mostly because I don't fully understand what is default.
Something from 5 years back:
sourceforge.net/p/emc/bugs/426/"Ok, I was helped to understand this better and it is not a bug. P does set the motion tolerance and Q sets Naive Cam Detector tolerance, but if Q is not specified it defaults to the same setting you give P. I fixed my problem by specifying Q0 or even Q0.001"
So unless things have changed this is the answer
As for me I've never used Q.
As I understand Q makes borders in two sides of path that tool can't move out.
So if you want to make pricese move simply use G61. And if not G64 Pn.
You can try if G64 P1 Q0 will be equal to G61
I think the light is starting to shine.
- Online
- Thank you received: 1369
to run out of the default TP lookahead with gcode consisting of many tiny G1 moves.
Revisiting the g-code overview docs this is stated clearly. I ended up on the trajectory planner page and got lost in the wilderness. For now I've programmed some small segment arcs and back plotting in Axis in an attempt to grasp the rest. If it doesn't sink in I'll stick with P only which has done okay so far.If Q is not specified it is set as Q=P.
- Online
