Single Ended Signaling from 7i76ED
07 Feb 2021 09:48 #197901
by Hamel2020
Single Ended Signaling from 7i76ED was created by Hamel2020
Hi ,,,
As I know that mesa 7i76e give a differential signal for (pulse and direction) to control the servo motor speed and direction , my question is : I have a servo drive needs a single ended signal to communicate with servo motor , can I get it from mesa , if yes , how the grounding will be ?
If some one have an idea , will be very helpful ..
thanks
thanks
07 Feb 2021 12:35 - 07 Feb 2021 12:36 #197912
Replied by PCW on topic Single Ended Signaling from 7i76ED
For single ended, you just use one output:
Common ground = common cathode = Step+, Dir+ and ground pin
Common +5V = common anode = Step-, Dir- and 5V pin
The unused differential outputs are left unconnected
Last edit: 07 Feb 2021 12:36 by PCW.
10 Feb 2021 07:38 #198250
by Hamel2020
Replied by Hamel2020 on topic Single Ended Signaling from 7i76ED
Hi Peter,
Thank you very much for your support ...
I have to supply a single -ended analog signal , and I have to use the TB2 form my Mesa card ,,,
my question is : how can I get an analog signal form TB2 ,
since the stp/dir signal is ( digital ??)
10 Feb 2021 16:03 #198284
What kind of analog signal do you need?
That is what range and precision do you need?
10 Feb 2021 16:12 #198286
by Hamel2020
I need a signal range -10 to +10V , send to my servo drive ...
10 Feb 2021 16:13 #198287
by Hamel2020
My servo drive type is Ormec G type
10 Feb 2021 16:17 #198288
by Hamel2020
10 Feb 2021 16:56 #198291
Is this for a spindle?
10 Feb 2021 16:59 #198293
by Hamel2020
No ... for servo motor in x direction ,
10 Feb 2021 17:11 #198296
OK so unfortunately its pretty awkward to just add support for a single
analog drive/encoder to a 7I76E. you could add a 7I83 for analog out
but you would need another daughter card to add an encoder input
(assuming the 7I76Es encoder is already dedicated to the spindle)
Time to create page: 0.151 seconds
