Single Ended Signaling from 7i76ED
10 Feb 2021 17:13 #198297
by Hamel2020
Replied by Hamel2020 on topic Single Ended Signaling from 7i76ED
What do you think about 7i77 ?
10 Feb 2021 17:24 #198301
Replied by PCW on topic Single Ended Signaling from 7i76ED
That would work but is also rather major overkill
10 Feb 2021 17:30 #198302
by Hamel2020
I know , but I have 5 servo motors all are the same , but in that case I will need a firmware for 7i76ed+7i77+7i85s ..
is that possible ?
is that possible ?
10 Feb 2021 17:39 #198304
OK so no step/dir?
If you have a 7I76ED and a 7I77 you probably dont need the 7I85S
since you already have 6 analog outputs and 7 encoder inputs
10 Feb 2021 17:46 #198305
by Hamel2020
- Unfortunately not ...
- I think Yes , so I have to have 7i76ed+7i77 firmware to flash the card ?
11 Feb 2021 18:55 #198424
Replied by andypugh on topic Single Ended Signaling from 7i76ED
You could consider a 7i92 + 7i77 and keep the 7i76E for the next project? (unless you need step/dir too. I haven't read back to the beginning)
Time to create page: 0.142 seconds
