Spindle override not fuction with g96
- papagno-source
14 Feb 2021 10:07 #198786
by papagno-source
Spindle override not fuction with g96 was created by papagno-source
Hi.
In lathe configuration, if run G96 d1000 M3 s200 the spindle tun good
but if change spindle override value not have effect .
Only in G97 have effect.
This is normal for linuxcnc or is a bug.
On anothe cnc the spindle value change velocith in both g97 and g96.
18 Feb 2021 11:33 #199237
Replied by andypugh on topic Spindle override not fuction with g96
Spindle override works on my lathe in both mode, but I use MPG connected to the motion pins.
How/where are you setting spindle override?
- papagno-source
22 Feb 2021 18:26 - 22 Feb 2021 18:33 #199747
by papagno-source
Replied by papagno-source on topic Spindle override not fuction with g96
I have connect count on halui.spindle.0.override.counts vaule the BCD override result.It change 50 to 120.
But i tomorrow ceck with halui.spindle.0.override.direct-value = true
Last edit: 22 Feb 2021 18:33 by papagno-source.
