Possible to remap M9?
- underscore
- Topic Author
16 Feb 2021 03:08 #199018
by underscore
Possible to remap M9? was created by underscore
Is it possible to remap M9? I’d like to add a third “coolant” option, namely air blast (e.g. by implementing M207 using digital out Hal pins). I’d like my air to be turned off by M9, just like M7 and M8.
According to the documentation it should not be possible, but even the examples contain m codes that shouldn’t be allowed but work.
I tried to remap, but that totally kills M9 all together.
16 Feb 2021 08:18 #199028
Replied by cmorley on topic Possible to remap M9?
cab you post your renaap code? was there an error message?
- underscore
- Topic Author
17 Feb 2021 04:06 #199129
by underscore
Replied by underscore on topic Possible to remap M9?
I'm using REMAP = M9 modalgroup=8 ngc=m9extended
I don't get an error message just the "old" behavior of M9
25 Feb 2021 15:49 #200104
I looked in the source code and M9 is not allowed to be remapped.
Not sure why.
I changed it and mostly had success remapping with python other then the active Mcode display did not update till another MDI command was sent.
I'm considering adding the change.
Not sure why.
- underscore
- Topic Author
26 Feb 2021 02:49 #200170
by underscore
Thanks for looking into that!
26 Feb 2021 06:22 #200174
Are you using master branch?
- underscore
- Topic Author
26 Feb 2021 13:15 #200193
by underscore
I am (via buildbot).
26 Feb 2021 16:47 #200203
Ok I just pushed the change - you'll have to wait for the buildbot to update.
Here is the python remap I tried, which just does what the original did.
i didn;t try remap with NGC.
As I said the controls do seem to turn off but the active gcode of m7/8 don;t change until another gcode is run.
Let me know what happens for you.
# pure python remaps
# REMAP=M6 python=remap_m9
def remap_m9(self,**words):
try:
emccanon.enqueue_MIST_OFF()
emccanon.enqueue_FLOOD_OFF()
return INTERP_OK
except Exception as e:
return "remap M9 failed: %s" % (e)
26 Feb 2021 21:52 #200241
by newbynobi
Replied by newbynobi on topic Possible to remap M9?
Chris, have you tried adding a G4 command?
In my remap es this helped.
Norbert
Norbert
26 Feb 2021 22:11 #200244
please explain more.
Time to create page: 0.178 seconds
