Teknic ClearCore USB port not showing up
- andrew2021
16 Feb 2021 09:54 - 16 Feb 2021 11:21 #199032
by andrew2021
Teknic ClearCore USB port not showing up was created by andrew2021
Hi there,
I have recently purchased a clear core motion and I/O controller as well as the recommended power supply.
I am having some issues getting the board to pick up as a device on the host pc running Windows 10. I have followed all the instructions thoroughly for automatic installation of clear core library and Atmel studio. As well as the Arduino wrapper. All code builds fine, and packages were installed correctly. The issue is that the device does not show up under any port connections in Arduino or in device manager.
I can validate that the ClearCore USB Serial Emulation Driver was installed successfully. I have tried following these instructions on various pcs to eliminate my pc as the potential issue.
I then began reading into the status led of the clear core device:
Off: is not powered properly.
Breathing: Normal running state. LEDs slowly fade in and out.
On: Processor has crashed. To recover, double-click the reset button to put the processor into bootloader mode, then upload safe code.
Error Code: A series of stobes and solid blinks indicate an error code that has occurred since the last time the processor was reset.
The blue status lights are permanently on from power on. This would indicate that the Processor has crashed. I then preceded to double click the reset button, however, this does not change the LED status. It is still continuously on.
There is no troubleshooting guideline other than issues they have experienced with windows 7 and usb drivers and that solution does not work either in my case.
Please can someone advise on possible solutions to try.
Last edit: 16 Feb 2021 11:21 by andrew2021.
- BeagleBrainz
- User is blocked
- Thank you received: 570
16 Feb 2021 11:27 #199047
by BeagleBrainz
Replied by BeagleBrainz on topic Teknic ClearCore USB port not showing up
As this forum is for support of Linuxcnc. (BTW no support for USB motion control with Linuxcnc)
I'd contact the supplier\manufacturer via email or phone. Or try any support FAQ pages they have.
Anyhow good luck.
Anyhow good luck.
- Teknic_Servo
- Thank you received: 4
22 Feb 2021 17:30 - 22 Feb 2021 17:44 #199730
by Teknic_Servo
Replied by Teknic_Servo on topic Teknic ClearCore USB port not showing up
Hi Andrew,
I'm an applications engineer with Teknic, and BeagleBrainz is correct - ClearCore doesn't currently support LinuxCNC so this is probably the wrong place to address your questions.
We are happy to work with you directly to try and resolve the issues that you're experiencing, so please give Teknic a call at 585-784-7454, or fill out a "contact request" at www.teknic.com/contact/.
Jim W. - Teknic Servo Systems Engineer
Last edit: 22 Feb 2021 17:44 by Teknic_Servo.
Time to create page: 0.155 seconds
