Homing problem
18 Feb 2021 18:57 #199331
by prochj51
Homing problem was created by prochj51
so far my machine was running without problems,
but from time to time when I hit home all, it tries to home Z axis first so it goes to the limit switch and it stays
there and gives me this error:
Note: Motion enabled after reaching a coordinate soft limit with active external offsets
I am not really sure what to do with it.
Would anyone know, please?
Config files attached
Thanks in advance
Jiri
Thanks in advance
Jiri
18 Feb 2021 20:33 #199344
by chris@cnc
Replied by chris@cnc on topic Homing problem
Hi Jiri,
Your home is to close to soft limit.
is in the ini.increase all axis to 1.000 and it should be working
is in the ini.
MAX_LIMIT = 0.01
18 Feb 2021 21:23 #199350
by Clive S
Z might have to be a minus number a -1
Replied by Clive S on topic Homing problem
Hi Jiri,
is in the ini.increase all axis to 1.000 and it should be workingMAX_LIMIT = 0.01
Time to create page: 0.130 seconds
