RPI 4 + Mesa 7c80 VFD Spindle Config
- BenStPierre
23 Feb 2021 02:42 - 23 Feb 2021 03:03 #199793
by BenStPierre
RPI 4 + Mesa 7c80 VFD Spindle Config was created by BenStPierre
Hello,
I've been reading many posts on the forum for a while now and there's a lot of information out there, but not much for the Mesa 7c80.
I'm currently running the master branch and have followed this post for the most part: forum.linuxcnc.org/27-driver-boards/40315-7c80-install-on-rpi-4
I'm trying to use the mesa analog spindle output to control my VFD and so far I'm stuck at the spindle enable pins. I have found that on the 7c80 spindle enable is gpio 20 and spindle direction is gpio 21, but I'm missing something somewhere because I can't get any spindle control output from the board itself.
I have found the issue to be the same as on this post: 162.243.45.186/39-pncconf/37417-spindle-...QNo6Gd3tGeITry6bKChE
but on the mesa 7c80. Can anybody point me out in the correct direction?
This is the error: ./metal_3D_printer.hal:363: Pin 'hm2_7c80.0.spinena' does not exist
What are the spindle pins for the 7c80?
I suspect that the firmware on the mesa needs to be flashed (now it's as received from Mesa) to enable the spindle output or something. running readhmid gives this: (I'll also attach the .hal and .ini)
And this is the booting scripts
Thanks in advance,
Ben
Configuration Name: HOSTMOT2
BoardName : MESA7C80
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 27
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for StepGens+Misc
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
TB7 2,3 0 IOPort StepGen 0 Step/Table1 (Out)
TB7 4,5 1 IOPort StepGen 0 Dir/Table2 (Out)
TB8 2,3 2 IOPort StepGen 1 Step/Table1 (Out)
TB8 4,5 3 IOPort StepGen 1 Dir/Table2 (Out)
TB9 2,3 4 IOPort StepGen 2 Step/Table1 (Out)
TB9 4,5 5 IOPort StepGen 2 Dir/Table2 (Out)
TB10 2,3 6 IOPort StepGen 3 Step/Table1 (Out)
TB10 4,5 7 IOPort StepGen 3 Dir/Table2 (Out)
TB11 2,3 8 IOPort StepGen 4 Step/Table1 (Out)
TB11 4,5 9 IOPort StepGen 4 Dir/Table2 (Out)
TB12 2,3 10 IOPort StepGen 5 Step/Table1 (Out)
TB13 4,5 11 IOPort StepGen 5 Dir/Table2 (Out)
TB3 3,4 12 IOPort SSerial 0 RXData0 (In)
TB3 5,6 13 IOPort SSerial 0 TXData0 (Out)
Internal 14 IOPort SSerial 0 TXEn0 (Out)
TB4 1,2 15 IOPort QCount 0 Quad-A (In)
TB4 4,5 16 IOPort QCount 0 Quad-B (In)
TB4 7,8 17 IOPort QCount 0 Quad-IDX (In)
TB5 2 18 IOPort PWM 0 PWM (Out)
TB5 2 19 IOPort PWM 0 /Enable (Out)
TB5 5,6 20 IOPort None
TB5 7,8Internal 21 IOPort None
Internal 22 IOPort InMux 0 Addr0 (Out)
Internal 23 IOPort InMux 0 Addr1 (Out)
Internal 24 IOPort InMux 0 Addr2 (Out)
Internal 25 IOPort InMux 0 Addr3 (Out)
(null) 26 IOPort InMux 0 Addr4 (Out)
IO Connections for Outputs+P1
Internal 27 IOPort InMux 0 Data0 (In)
TB13 1,2 28 IOPort SSR 0 Out-00 (Out)
TB13 3,4 29 IOPort SSR 0 Out-01 (Out)
TB13 5,6 30 IOPort SSR 0 Out-02 (Out)
TB13 7,8 31 IOPort SSR 0 Out-03 (Out)
TB14 1,2 32 IOPort SSR 0 Out-04 (Out)
TB14 3,4 33 IOPort SSR 0 Out-05 (Out)
TB14 5,6 34 IOPort SSR 0 Out-06 (Out)
TB14 7,8 35 IOPort SSR 0 Out-07 (Out)
Internal 36 IOPort SSR 0 AC Ref (Out)
P1 1 37 IOPort None
P1 14 38 IOPort None
P1 2 39 IOPort None
P1 15 40 IOPort None
P1 3 41 IOPort None
P1 16 42 IOPort None
P1 4 43 IOPort None
P1 17 44 IOPort None
P1 5 45 IOPort None
P1 6 46 IOPort None
P1 7 47 IOPort None
P1 8 48 IOPort None
P1 9 49 IOPort None
P1 10 50 IOPort None
P1 11 51 IOPort None
P1 12 52 IOPort None
P1 13 53 IOPort NoneAnd this is the booting scripts
pi@linuxcnc:~/linuxcnc-dev/scripts $ linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/pi/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'metal_3D_printer.ini'
Starting LinuxCNC...
Found file(REL): ./metal_3D_printer.hal
Note: Using POSIX realtime
trivkins: coordinates:XYYZA
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
Joint 4 ==> Axis A
hm2/hm2_7c80.0: Low Level init 0.15
hm2/hm2_7c80.0: Smart Serial Firmware Version 43
hm2/hm2_7c80.0: 54 I/O Pins used:
hm2/hm2_7c80.0: IO Pin 000 (TB07-02/TB07-03): StepGen #0, pin Step (Output)
hm2/hm2_7c80.0: IO Pin 001 (TB07-04/TB07-05): StepGen #0, pin Direction (Output)
hm2/hm2_7c80.0: IO Pin 002 (TB08-02/TB08-03): StepGen #1, pin Step (Output)
hm2/hm2_7c80.0: IO Pin 003 (TB08-04/TB08-05): StepGen #1, pin Direction (Output)
hm2/hm2_7c80.0: IO Pin 004 (TB09-02/TB09-03): StepGen #2, pin Step (Output)
hm2/hm2_7c80.0: IO Pin 005 (TB09-04/TB09-05): StepGen #2, pin Direction (Output)
hm2/hm2_7c80.0: IO Pin 006 (TB10-02/TB10-03): StepGen #3, pin Step (Output)
hm2/hm2_7c80.0: IO Pin 007 (TB10-04/TB10-05): StepGen #3, pin Direction (Output)
hm2/hm2_7c80.0: IO Pin 008 (TB11-02/TB11-03): StepGen #4, pin Step (Output)
hm2/hm2_7c80.0: IO Pin 009 (TB11-04/TB11-05): StepGen #4, pin Direction (Output)
hm2/hm2_7c80.0: IO Pin 010 (TB12-02/TB12-03): IOPort
hm2/hm2_7c80.0: IO Pin 011 (TB12-04/TB12-05): IOPort
hm2/hm2_7c80.0: IO Pin 012 (TB03-03/TB04-04): IOPort
hm2/hm2_7c80.0: IO Pin 013 (TB03-05/TB04-06): IOPort
hm2/hm2_7c80.0: IO Pin 014 (TB03-05/TB03-06): IOPort
hm2/hm2_7c80.0: IO Pin 015 (TB04-01/TB04-02): IOPort
hm2/hm2_7c80.0: IO Pin 016 (TB04-04/TB04-05): IOPort
hm2/hm2_7c80.0: IO Pin 017 (TB04-07/TB04-08): IOPort
hm2/hm2_7c80.0: IO Pin 018 (TB05-02): IOPort
hm2/hm2_7c80.0: IO Pin 019 (TB05-02): IOPort
hm2/hm2_7c80.0: IO Pin 020 (TB05-05/TB05-06): IOPort
hm2/hm2_7c80.0: IO Pin 021 (TB05-07/TB05-08): IOPort
hm2/hm2_7c80.0: IO Pin 022 (Internal InMux0): InMux Input Mux #0, pin addr0 (Output)
hm2/hm2_7c80.0: IO Pin 023 (Internal InMux1): InMux Input Mux #0, pin addr1 (Output)
hm2/hm2_7c80.0: IO Pin 024 (Internal InMux2): InMux Input Mux #0, pin addr2 (Output)
hm2/hm2_7c80.0: IO Pin 025 (Internal InMux3): InMux Input Mux #0, pin addr3 (Output)
hm2/hm2_7c80.0: IO Pin 026 (Internal InMux4): InMux Input Mux #0, pin addr4 (Output)
hm2/hm2_7c80.0: IO Pin 027 (Internal InMuxData): InMux Input Mux #0, pin muxdata (Input)
hm2/hm2_7c80.0: IO Pin 028 (TB13-01/TB13-02): SSR #0, pin Out-00 (Output)
hm2/hm2_7c80.0: IO Pin 029 (TB13-03/TB13-04): SSR #0, pin Out-01 (Output)
hm2/hm2_7c80.0: IO Pin 030 (TB13-05/TB13-06): SSR #0, pin Out-02 (Output)
hm2/hm2_7c80.0: IO Pin 031 (TB13-07/TB13-08): SSR #0, pin Out-03 (Output)
hm2/hm2_7c80.0: IO Pin 032 (TB14-01/TB14-02): SSR #0, pin Out-04 (Output)
hm2/hm2_7c80.0: IO Pin 033 (TB14-03/TB14-04): SSR #0, pin Out-05 (Output)
hm2/hm2_7c80.0: IO Pin 034 (TB14-05/TB14-06): SSR #0, pin Out-06 (Output)
hm2/hm2_7c80.0: IO Pin 035 (TB14-07/TB14-08): SSR #0, pin Out-07 (Output)
hm2/hm2_7c80.0: IO Pin 036 (Internal SSR): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7c80.0: IO Pin 037 (P1-01): IOPort
hm2/hm2_7c80.0: IO Pin 038 (P1-02): IOPort
hm2/hm2_7c80.0: IO Pin 039 (P1-03): IOPort
hm2/hm2_7c80.0: IO Pin 040 (P1-04): IOPort
hm2/hm2_7c80.0: IO Pin 041 (P1-05): IOPort
hm2/hm2_7c80.0: IO Pin 042 (P1-06): IOPort
hm2/hm2_7c80.0: IO Pin 043 (P1-07): IOPort
hm2/hm2_7c80.0: IO Pin 044 (P1-08): IOPort
hm2/hm2_7c80.0: IO Pin 045 (P1-09): IOPort
hm2/hm2_7c80.0: IO Pin 046 (P1-11): IOPort
hm2/hm2_7c80.0: IO Pin 047 (P1-13): IOPort
hm2/hm2_7c80.0: IO Pin 048 (P1-15): IOPort
hm2/hm2_7c80.0: IO Pin 049 (P1-17): IOPort
hm2/hm2_7c80.0: IO Pin 050 (P1-19): IOPort
hm2/hm2_7c80.0: IO Pin 051 (P1-21): IOPort
hm2/hm2_7c80.0: IO Pin 052 (P1-23): IOPort
hm2/hm2_7c80.0: IO Pin 053 (P1-25): IOPort
hm2/hm2_7c80.0: registered
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/pi/linuxcnc_debug.txt
and
/home/pi/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminalThanks in advance,
Ben
Last edit: 23 Feb 2021 03:03 by BenStPierre.
- Thank you received: 5261
23 Feb 2021 15:49 #199842
Replied by PCW on topic RPI 4 + Mesa 7c80 VFD Spindle Config
Spindle analog output on a 7C80 is controlled by the PWMgen (PWMgen 0)
- BenStPierre
23 Feb 2021 17:13 #199860
by BenStPierre
Replied by BenStPierre on topic RPI 4 + Mesa 7c80 VFD Spindle Config
Thank PCW for answering!
I think I'm confused, is the analog output and the 0-10v+ virtual potentiometer the same thing?
my VFD is wired to the SP-, SP and SP+ pins on the 7c80.
So what should I follow on this page (linuxcnc.org/docs/html/examples/spindle.html) the VFD or PWM HAL setup?
Thanks again
Ben
Thanks again
Ben
23 Feb 2021 17:59 - 23 Feb 2021 17:59 #199868
No, you would setup the Mesa hardware PWM.
To list the available pins/parameters you can type these commands
while linuxCNC is running:
halcmd show pin hm2_7c80.0.pwm
halcmd show param hm2_7c80.0.pwm
Last edit: 23 Feb 2021 17:59 by PCW.
The following user(s) said Thank You: rdtsc
- BenStPierre
24 Feb 2021 17:26 #200007
by BenStPierre
Hey thanks for the reply, but when I do this with LinuxCNC running there are no PWM pins or parameters. Does this mean I have to flash the mesa to configure it?
Thanks in advance,
Ben
Thanks in advance,
Ben
pi@linuxcnc:~ $ halcmd show pin hm2_7c80.0.pwm
Component Pins:
Owner Type Dir Value Name
pi@linuxcnc:~ $ halcmd show param hm2_7c80.0.pwm
Parameters:
Component Pins:
26 float IN -50 hm2_7c80.0.dpll.01.timer-us
26 float IN 100 hm2_7c80.0.dpll.02.timer-us
26 float IN 100 hm2_7c80.0.dpll.03.timer-us
26 float IN 100 hm2_7c80.0.dpll.04.timer-us
26 float IN 1 hm2_7c80.0.dpll.base-freq-khz
26 u32 OUT 0x0000002A hm2_7c80.0.dpll.ddsize
26 float OUT 2.811547 hm2_7c80.0.dpll.phase-error-us
26 u32 IN 0x00400000 hm2_7c80.0.dpll.plimit
26 u32 OUT 0x00000018 hm2_7c80.0.dpll.prescale
26 u32 IN 0x000007D0 hm2_7c80.0.dpll.time-const
26 bit OUT FALSE hm2_7c80.0.gpio.000.in
26 bit OUT TRUE hm2_7c80.0.gpio.000.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.001.in
26 bit OUT TRUE hm2_7c80.0.gpio.001.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.002.in
26 bit OUT TRUE hm2_7c80.0.gpio.002.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.003.in
26 bit OUT TRUE hm2_7c80.0.gpio.003.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.004.in
26 bit OUT TRUE hm2_7c80.0.gpio.004.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.005.in
26 bit OUT TRUE hm2_7c80.0.gpio.005.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.006.in
26 bit OUT TRUE hm2_7c80.0.gpio.006.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.007.in
26 bit OUT TRUE hm2_7c80.0.gpio.007.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.008.in
26 bit OUT TRUE hm2_7c80.0.gpio.008.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.009.in
26 bit OUT TRUE hm2_7c80.0.gpio.009.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.010.in
26 bit OUT TRUE hm2_7c80.0.gpio.010.in_not
26 bit IN FALSE hm2_7c80.0.gpio.010.out
26 bit OUT FALSE hm2_7c80.0.gpio.011.in
26 bit OUT TRUE hm2_7c80.0.gpio.011.in_not
26 bit IN FALSE hm2_7c80.0.gpio.011.out
26 bit OUT TRUE hm2_7c80.0.gpio.012.in
26 bit OUT FALSE hm2_7c80.0.gpio.012.in_not
26 bit IN FALSE hm2_7c80.0.gpio.012.out
26 bit OUT FALSE hm2_7c80.0.gpio.013.in
26 bit OUT TRUE hm2_7c80.0.gpio.013.in_not
26 bit IN FALSE hm2_7c80.0.gpio.013.out
26 bit OUT FALSE hm2_7c80.0.gpio.014.in
26 bit OUT TRUE hm2_7c80.0.gpio.014.in_not
26 bit IN FALSE hm2_7c80.0.gpio.014.out
26 bit OUT FALSE hm2_7c80.0.gpio.015.in
26 bit OUT TRUE hm2_7c80.0.gpio.015.in_not
26 bit IN FALSE hm2_7c80.0.gpio.015.out
26 bit OUT FALSE hm2_7c80.0.gpio.016.in
26 bit OUT TRUE hm2_7c80.0.gpio.016.in_not
26 bit IN FALSE hm2_7c80.0.gpio.016.out
26 bit OUT FALSE hm2_7c80.0.gpio.017.in
26 bit OUT TRUE hm2_7c80.0.gpio.017.in_not
26 bit IN FALSE hm2_7c80.0.gpio.017.out
26 bit OUT TRUE hm2_7c80.0.gpio.018.in
26 bit OUT FALSE hm2_7c80.0.gpio.018.in_not
26 bit IN FALSE hm2_7c80.0.gpio.018.out
26 bit OUT TRUE hm2_7c80.0.gpio.019.in
26 bit OUT FALSE hm2_7c80.0.gpio.019.in_not
26 bit IN FALSE hm2_7c80.0.gpio.019.out
26 bit OUT TRUE hm2_7c80.0.gpio.020.in
26 bit OUT FALSE hm2_7c80.0.gpio.020.in_not
26 bit IN FALSE hm2_7c80.0.gpio.020.out <== machine-is-enabled
26 bit OUT TRUE hm2_7c80.0.gpio.021.in
26 bit OUT FALSE hm2_7c80.0.gpio.021.in_not
26 bit IN FALSE hm2_7c80.0.gpio.021.out <== spindle-ccw
26 bit OUT FALSE hm2_7c80.0.gpio.022.in
26 bit OUT TRUE hm2_7c80.0.gpio.022.in_not
26 bit OUT TRUE hm2_7c80.0.gpio.023.in
26 bit OUT FALSE hm2_7c80.0.gpio.023.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.024.in
26 bit OUT TRUE hm2_7c80.0.gpio.024.in_not
26 bit OUT TRUE hm2_7c80.0.gpio.025.in
26 bit OUT FALSE hm2_7c80.0.gpio.025.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.026.in
26 bit OUT TRUE hm2_7c80.0.gpio.026.in_not
26 bit OUT TRUE hm2_7c80.0.gpio.027.in
26 bit OUT FALSE hm2_7c80.0.gpio.027.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.028.in
26 bit OUT TRUE hm2_7c80.0.gpio.028.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.029.in
26 bit OUT TRUE hm2_7c80.0.gpio.029.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.030.in
26 bit OUT TRUE hm2_7c80.0.gpio.030.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.031.in
26 bit OUT TRUE hm2_7c80.0.gpio.031.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.032.in
26 bit OUT TRUE hm2_7c80.0.gpio.032.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.033.in
26 bit OUT TRUE hm2_7c80.0.gpio.033.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.034.in
26 bit OUT TRUE hm2_7c80.0.gpio.034.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.035.in
26 bit OUT TRUE hm2_7c80.0.gpio.035.in_not
26 bit OUT FALSE hm2_7c80.0.gpio.036.in
26 bit OUT TRUE hm2_7c80.0.gpio.036.in_not
26 bit OUT TRUE hm2_7c80.0.gpio.037.in
26 bit OUT FALSE hm2_7c80.0.gpio.037.in_not
26 bit IN FALSE hm2_7c80.0.gpio.037.out
26 bit OUT TRUE hm2_7c80.0.gpio.038.in
26 bit OUT FALSE hm2_7c80.0.gpio.038.in_not
26 bit IN FALSE hm2_7c80.0.gpio.038.out
26 bit OUT TRUE hm2_7c80.0.gpio.039.in
26 bit OUT FALSE hm2_7c80.0.gpio.039.in_not
26 bit IN FALSE hm2_7c80.0.gpio.039.out
26 bit OUT TRUE hm2_7c80.0.gpio.040.in
26 bit OUT FALSE hm2_7c80.0.gpio.040.in_not
26 bit IN FALSE hm2_7c80.0.gpio.040.out
26 bit OUT TRUE hm2_7c80.0.gpio.041.in
26 bit OUT FALSE hm2_7c80.0.gpio.041.in_not
26 bit IN FALSE hm2_7c80.0.gpio.041.out
26 bit OUT TRUE hm2_7c80.0.gpio.042.in
26 bit OUT FALSE hm2_7c80.0.gpio.042.in_not
26 bit IN FALSE hm2_7c80.0.gpio.042.out
26 bit OUT TRUE hm2_7c80.0.gpio.043.in
26 bit OUT FALSE hm2_7c80.0.gpio.043.in_not
26 bit IN FALSE hm2_7c80.0.gpio.043.out
26 bit OUT TRUE hm2_7c80.0.gpio.044.in
26 bit OUT FALSE hm2_7c80.0.gpio.044.in_not
26 bit IN FALSE hm2_7c80.0.gpio.044.out
26 bit OUT TRUE hm2_7c80.0.gpio.045.in
26 bit OUT FALSE hm2_7c80.0.gpio.045.in_not
26 bit IN FALSE hm2_7c80.0.gpio.045.out
26 bit OUT TRUE hm2_7c80.0.gpio.046.in
26 bit OUT FALSE hm2_7c80.0.gpio.046.in_not
26 bit IN FALSE hm2_7c80.0.gpio.046.out
26 bit OUT TRUE hm2_7c80.0.gpio.047.in
26 bit OUT FALSE hm2_7c80.0.gpio.047.in_not
26 bit IN FALSE hm2_7c80.0.gpio.047.out
26 bit OUT TRUE hm2_7c80.0.gpio.048.in
26 bit OUT FALSE hm2_7c80.0.gpio.048.in_not
26 bit IN FALSE hm2_7c80.0.gpio.048.out
26 bit OUT TRUE hm2_7c80.0.gpio.049.in
26 bit OUT FALSE hm2_7c80.0.gpio.049.in_not
26 bit IN FALSE hm2_7c80.0.gpio.049.out
26 bit OUT TRUE hm2_7c80.0.gpio.050.in
26 bit OUT FALSE hm2_7c80.0.gpio.050.in_not
26 bit IN FALSE hm2_7c80.0.gpio.050.out
26 bit OUT TRUE hm2_7c80.0.gpio.051.in
26 bit OUT FALSE hm2_7c80.0.gpio.051.in_not
26 bit IN FALSE hm2_7c80.0.gpio.051.out
26 bit OUT TRUE hm2_7c80.0.gpio.052.in
26 bit OUT FALSE hm2_7c80.0.gpio.052.in_not
26 bit IN FALSE hm2_7c80.0.gpio.052.out
26 bit OUT TRUE hm2_7c80.0.gpio.053.in
26 bit OUT FALSE hm2_7c80.0.gpio.053.in_not
26 bit IN FALSE hm2_7c80.0.gpio.053.out
26 s32 OUT 0 hm2_7c80.0.inmux.00.enc0-count
26 s32 OUT 0 hm2_7c80.0.inmux.00.enc1-count
26 s32 OUT 0 hm2_7c80.0.inmux.00.enc2-count
26 s32 OUT 0 hm2_7c80.0.inmux.00.enc3-count
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-00 ==> min-x
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-00-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-00-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-01 ==> min-y
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-01-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-01-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-02 ==> min-y2
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-02-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-02-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-03 ==> min-z
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-03-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-03-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-04
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-04-not ==> estop-ext
26 bit IN FALSE hm2_7c80.0.inmux.00.input-04-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-05 ==> cycle_start
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-05-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-05-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-06 ==> feed_hold
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-06-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-06-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-07 ==> stop_program
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-07-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-07-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-08 ==> probe-in
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-08-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-08-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-09
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-09-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-09-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-10
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-10-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-10-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-11
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-11-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-11-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-12
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-12-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-12-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-13
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-13-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-13-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-14
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-14-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-14-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-15
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-15-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-15-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-16
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-16-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-16-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-17
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-17-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-17-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-18
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-18-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-18-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-19
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-19-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-19-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-20
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-20-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-20-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-21
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-21-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-21-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-22
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-22-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-22-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.input-23
26 bit OUT TRUE hm2_7c80.0.inmux.00.input-23-not
26 bit IN FALSE hm2_7c80.0.inmux.00.input-23-slow
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-00
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-00-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-01
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-01-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-02
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-02-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-03
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-03-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-04
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-04-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-05
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-05-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-06
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-06-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-07
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-07-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-08
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-08-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-09
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-09-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-10
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-10-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-11
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-11-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-12
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-12-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-13
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-13-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-14
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-14-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-15
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-15-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-16
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-16-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-17
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-17-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-18
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-18-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-19
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-19-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-20
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-20-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-21
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-21-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-22
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-22-not
26 bit OUT FALSE hm2_7c80.0.inmux.00.raw-input-23
26 bit OUT TRUE hm2_7c80.0.inmux.00.raw-input-23-not
26 bit IN FALSE hm2_7c80.0.led.CR01
26 bit IN FALSE hm2_7c80.0.led.CR02
26 bit IN FALSE hm2_7c80.0.led.CR03
26 bit IN FALSE hm2_7c80.0.led.CR04
26 s32 OUT 35406 hm2_7c80.0.read.time
26 bit IN FALSE hm2_7c80.0.ssr.00.out-00 <== welder
26 bit IN FALSE hm2_7c80.0.ssr.00.out-01 <== argon
26 bit IN FALSE hm2_7c80.0.ssr.00.out-02 <== cooling-pump
26 bit IN FALSE hm2_7c80.0.ssr.00.out-03 <== cooling-fan
26 bit IN FALSE hm2_7c80.0.ssr.00.out-04
26 bit IN FALSE hm2_7c80.0.ssr.00.out-05
26 bit IN FALSE hm2_7c80.0.ssr.00.out-06
26 bit IN FALSE hm2_7c80.0.ssr.00.out-07
26 u32 IN 0x000F4240 hm2_7c80.0.ssr.00.rate
26 bit IN TRUE hm2_7c80.0.stepgen.00.control-type
26 s32 OUT 0 hm2_7c80.0.stepgen.00.counts
26 float OUT 0 hm2_7c80.0.stepgen.00.dbg_err_at_match
26 float OUT 0 hm2_7c80.0.stepgen.00.dbg_ff_vel
26 float OUT 0 hm2_7c80.0.stepgen.00.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7c80.0.stepgen.00.dbg_s_to_match
26 s32 OUT 0 hm2_7c80.0.stepgen.00.dbg_step_rate
26 float OUT 0 hm2_7c80.0.stepgen.00.dbg_vel_error
26 bit IN FALSE hm2_7c80.0.stepgen.00.enable <== x-enable
26 float IN 0 hm2_7c80.0.stepgen.00.position-cmd
26 float OUT 0 hm2_7c80.0.stepgen.00.position-fb ==> x-pos-fb
26 bit IN FALSE hm2_7c80.0.stepgen.00.position-reset
26 float IN 0 hm2_7c80.0.stepgen.00.velocity-cmd <== x-output
26 float OUT 0 hm2_7c80.0.stepgen.00.velocity-fb
26 bit IN TRUE hm2_7c80.0.stepgen.01.control-type
26 s32 OUT 0 hm2_7c80.0.stepgen.01.counts
26 float OUT 0 hm2_7c80.0.stepgen.01.dbg_err_at_match
26 float OUT 0 hm2_7c80.0.stepgen.01.dbg_ff_vel
26 float OUT 0 hm2_7c80.0.stepgen.01.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7c80.0.stepgen.01.dbg_s_to_match
26 s32 OUT 0 hm2_7c80.0.stepgen.01.dbg_step_rate
26 float OUT 0 hm2_7c80.0.stepgen.01.dbg_vel_error
26 bit IN FALSE hm2_7c80.0.stepgen.01.enable <== y-enable
26 float IN 0 hm2_7c80.0.stepgen.01.position-cmd
26 float OUT 0 hm2_7c80.0.stepgen.01.position-fb ==> y-pos-fb
26 bit IN FALSE hm2_7c80.0.stepgen.01.position-reset
26 float IN 0 hm2_7c80.0.stepgen.01.velocity-cmd <== y-output
26 float OUT 0 hm2_7c80.0.stepgen.01.velocity-fb
26 bit IN TRUE hm2_7c80.0.stepgen.02.control-type
26 s32 OUT 0 hm2_7c80.0.stepgen.02.counts
26 float OUT 0 hm2_7c80.0.stepgen.02.dbg_err_at_match
26 float OUT 0 hm2_7c80.0.stepgen.02.dbg_ff_vel
26 float OUT 0 hm2_7c80.0.stepgen.02.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7c80.0.stepgen.02.dbg_s_to_match
26 s32 OUT 0 hm2_7c80.0.stepgen.02.dbg_step_rate
26 float OUT 0 hm2_7c80.0.stepgen.02.dbg_vel_error
26 bit IN FALSE hm2_7c80.0.stepgen.02.enable <== y2-enable
26 float IN 0 hm2_7c80.0.stepgen.02.position-cmd
26 float OUT 0 hm2_7c80.0.stepgen.02.position-fb ==> y2-pos-fb
26 bit IN FALSE hm2_7c80.0.stepgen.02.position-reset
26 float IN 0 hm2_7c80.0.stepgen.02.velocity-cmd <== y2-output
26 float OUT 0 hm2_7c80.0.stepgen.02.velocity-fb
26 bit IN TRUE hm2_7c80.0.stepgen.03.control-type
26 s32 OUT 0 hm2_7c80.0.stepgen.03.counts
26 float OUT 0 hm2_7c80.0.stepgen.03.dbg_err_at_match
26 float OUT 0 hm2_7c80.0.stepgen.03.dbg_ff_vel
26 float OUT 0 hm2_7c80.0.stepgen.03.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7c80.0.stepgen.03.dbg_s_to_match
26 s32 OUT 0 hm2_7c80.0.stepgen.03.dbg_step_rate
26 float OUT 0 hm2_7c80.0.stepgen.03.dbg_vel_error
26 bit IN FALSE hm2_7c80.0.stepgen.03.enable <== z-enable
26 float IN 0 hm2_7c80.0.stepgen.03.position-cmd
26 float OUT 0 hm2_7c80.0.stepgen.03.position-fb ==> z-pos-fb
26 bit IN FALSE hm2_7c80.0.stepgen.03.position-reset
26 float IN 0 hm2_7c80.0.stepgen.03.velocity-cmd <== z-output
26 float OUT 0 hm2_7c80.0.stepgen.03.velocity-fb
26 bit IN TRUE hm2_7c80.0.stepgen.04.control-type
26 s32 OUT 0 hm2_7c80.0.stepgen.04.counts
26 float OUT 0 hm2_7c80.0.stepgen.04.dbg_err_at_match
26 float OUT 0 hm2_7c80.0.stepgen.04.dbg_ff_vel
26 float OUT 0 hm2_7c80.0.stepgen.04.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7c80.0.stepgen.04.dbg_s_to_match
26 s32 OUT 0 hm2_7c80.0.stepgen.04.dbg_step_rate
26 float OUT 0 hm2_7c80.0.stepgen.04.dbg_vel_error
26 bit IN FALSE hm2_7c80.0.stepgen.04.enable <== a-enable
26 float IN 0 hm2_7c80.0.stepgen.04.position-cmd
26 float OUT 0 hm2_7c80.0.stepgen.04.position-fb ==> a-pos-fb
26 bit IN FALSE hm2_7c80.0.stepgen.04.position-reset
26 float IN 0 hm2_7c80.0.stepgen.04.velocity-cmd <== a-output
26 float OUT 0 hm2_7c80.0.stepgen.04.velocity-fb
26 s32 IN 1 hm2_7c80.0.stepgen.timer-number
26 bit I/O FALSE hm2_7c80.0.watchdog.has_bit
26 s32 OUT 29592 hm2_7c80.0.write.time
Parameters:
26 bit RW FALSE hm2_7c80.0.gpio.010.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.010.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.010.is_output
26 bit RW FALSE hm2_7c80.0.gpio.011.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.011.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.011.is_output
26 bit RW FALSE hm2_7c80.0.gpio.012.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.012.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.012.is_output
26 bit RW FALSE hm2_7c80.0.gpio.013.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.013.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.013.is_output
26 bit RW FALSE hm2_7c80.0.gpio.014.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.014.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.014.is_output
26 bit RW FALSE hm2_7c80.0.gpio.015.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.015.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.015.is_output
26 bit RW FALSE hm2_7c80.0.gpio.016.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.016.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.016.is_output
26 bit RW FALSE hm2_7c80.0.gpio.017.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.017.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.017.is_output
26 bit RW FALSE hm2_7c80.0.gpio.018.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.018.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.018.is_output
26 bit RW FALSE hm2_7c80.0.gpio.019.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.019.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.019.is_output
26 bit RW FALSE hm2_7c80.0.gpio.020.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.020.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.020.is_output
26 bit RW FALSE hm2_7c80.0.gpio.021.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.021.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.021.is_output
26 bit RW FALSE hm2_7c80.0.gpio.022.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.022.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.023.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.023.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.024.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.024.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.025.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.025.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.026.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.026.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.028.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.028.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.029.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.029.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.030.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.030.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.031.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.031.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.032.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.032.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.033.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.033.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.034.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.034.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.035.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.035.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.036.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.036.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.037.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.037.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.037.is_output
26 bit RW FALSE hm2_7c80.0.gpio.038.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.038.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.038.is_output
26 bit RW FALSE hm2_7c80.0.gpio.039.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.039.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.039.is_output
26 bit RW FALSE hm2_7c80.0.gpio.040.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.040.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.040.is_output
26 bit RW FALSE hm2_7c80.0.gpio.041.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.041.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.041.is_output
26 bit RW FALSE hm2_7c80.0.gpio.042.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.042.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.042.is_output
26 bit RW FALSE hm2_7c80.0.gpio.043.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.043.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.043.is_output
26 bit RW FALSE hm2_7c80.0.gpio.044.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.044.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.044.is_output
26 bit RW FALSE hm2_7c80.0.gpio.045.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.045.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.045.is_output
26 bit RW FALSE hm2_7c80.0.gpio.046.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.046.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.046.is_output
26 bit RW FALSE hm2_7c80.0.gpio.047.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.047.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.047.is_output
26 bit RW FALSE hm2_7c80.0.gpio.048.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.048.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.048.is_output
26 bit RW FALSE hm2_7c80.0.gpio.049.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.049.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.049.is_output
26 bit RW FALSE hm2_7c80.0.gpio.050.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.050.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.050.is_output
26 bit RW FALSE hm2_7c80.0.gpio.051.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.051.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.051.is_output
26 bit RW FALSE hm2_7c80.0.gpio.052.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.052.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.052.is_output
26 bit RW FALSE hm2_7c80.0.gpio.053.invert_output
26 bit RW FALSE hm2_7c80.0.gpio.053.is_opendrain
26 bit RW FALSE hm2_7c80.0.gpio.053.is_output
26 bit RW FALSE hm2_7c80.0.inmux.00.enc0_4xmode
26 bit RW FALSE hm2_7c80.0.inmux.00.enc1_4xmode
26 bit RW FALSE hm2_7c80.0.inmux.00.enc2_4xmode
26 bit RW FALSE hm2_7c80.0.inmux.00.enc3_4xmode
26 u32 RW 0x00000005 hm2_7c80.0.inmux.00.fast_scans
26 u32 RW 0x00004E20 hm2_7c80.0.inmux.00.scan_rate
26 u32 RO 0x00000018 hm2_7c80.0.inmux.00.scan_width
26 u32 RW 0x000001F4 hm2_7c80.0.inmux.00.slow_scans
26 bit RW FALSE hm2_7c80.0.io_error
26 s32 RW 113350 hm2_7c80.0.read.tmax
26 bit RO FALSE hm2_7c80.0.read.tmax-increased
26 bit RW FALSE hm2_7c80.0.stepgen.00.direction.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.00.direction.is_opendrain
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.00.dirhold
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.00.dirsetup
26 float RW 37.5 hm2_7c80.0.stepgen.00.maxaccel
26 float RW 1.25 hm2_7c80.0.stepgen.00.maxvel
26 float RW 2032 hm2_7c80.0.stepgen.00.position-scale
26 bit RW FALSE hm2_7c80.0.stepgen.00.step.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.00.step.is_opendrain
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.00.step_type
26 u32 RW 0x00001770 hm2_7c80.0.stepgen.00.steplen
26 u32 RW 0x00001770 hm2_7c80.0.stepgen.00.stepspace
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.00.table-data-0
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.00.table-data-1
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.00.table-data-2
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.00.table-data-3
26 bit RW FALSE hm2_7c80.0.stepgen.01.direction.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.01.direction.is_opendrain
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.01.dirhold
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.01.dirsetup
26 float RW 37.5 hm2_7c80.0.stepgen.01.maxaccel
26 float RW 1.25 hm2_7c80.0.stepgen.01.maxvel
26 float RW 200 hm2_7c80.0.stepgen.01.position-scale
26 bit RW FALSE hm2_7c80.0.stepgen.01.step.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.01.step.is_opendrain
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.01.step_type
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.01.steplen
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.01.stepspace
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.01.table-data-0
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.01.table-data-1
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.01.table-data-2
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.01.table-data-3
26 bit RW FALSE hm2_7c80.0.stepgen.02.direction.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.02.direction.is_opendrain
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.02.dirhold
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.02.dirsetup
26 float RW 37.5 hm2_7c80.0.stepgen.02.maxaccel
26 float RW 1.25 hm2_7c80.0.stepgen.02.maxvel
26 float RW 200 hm2_7c80.0.stepgen.02.position-scale
26 bit RW FALSE hm2_7c80.0.stepgen.02.step.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.02.step.is_opendrain
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.02.step_type
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.02.steplen
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.02.stepspace
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.02.table-data-0
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.02.table-data-1
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.02.table-data-2
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.02.table-data-3
26 bit RW FALSE hm2_7c80.0.stepgen.03.direction.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.03.direction.is_opendrain
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.03.dirhold
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.03.dirsetup
26 float RW 37.5 hm2_7c80.0.stepgen.03.maxaccel
26 float RW 1.25 hm2_7c80.0.stepgen.03.maxvel
26 float RW 200 hm2_7c80.0.stepgen.03.position-scale
26 bit RW FALSE hm2_7c80.0.stepgen.03.step.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.03.step.is_opendrain
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.03.step_type
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.03.steplen
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.03.stepspace
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.03.table-data-0
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.03.table-data-1
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.03.table-data-2
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.03.table-data-3
26 bit RW FALSE hm2_7c80.0.stepgen.04.direction.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.04.direction.is_opendrain
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.04.dirhold
26 u32 RW 0x00002710 hm2_7c80.0.stepgen.04.dirsetup
26 float RW 37.5 hm2_7c80.0.stepgen.04.maxaccel
26 float RW 1.25 hm2_7c80.0.stepgen.04.maxvel
26 float RW 200 hm2_7c80.0.stepgen.04.position-scale
26 bit RW FALSE hm2_7c80.0.stepgen.04.step.invert_output
26 bit RW FALSE hm2_7c80.0.stepgen.04.step.is_opendrain
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.04.step_type
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.04.steplen
26 u32 RW 0x00001388 hm2_7c80.0.stepgen.04.stepspace
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.04.table-data-0
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.04.table-data-1
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.04.table-data-2
26 u32 RW 0x00000000 hm2_7c80.0.stepgen.04.table-data-3
26 u32 RW 0x004C4B40 hm2_7c80.0.watchdog.timeout_ns
26 s32 RW 135646 hm2_7c80.0.write.tmax
26 bit RO FALSE hm2_7c80.0.write.tmax-increased
pi@linuxcnc:~ $ Please Log in or Create an account to join the conversation.
24 Feb 2021 19:44 - 24 Feb 2021 19:44 #200017
The firmware contains 1 PWMgen for the spindle:
It likely you have the PWM generator disabled in your hal or ini ifile
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Instance Stride: 4 bytesIt likely you have the PWM generator disabled in your hal or ini ifile
Last edit: 24 Feb 2021 19:44 by PCW.
- Clive S
- Thank you received: 486
24 Feb 2021 22:50 #200044
by Clive S
You have
loadrt hm2_rpspi config=" num_encoders=0 num_pwmgens=0 num_stepgens=5"
try
loadrt hm2_rpspi config=" num_encoders=0 num_pwmgens=1 num_stepgens=5"
Replied by Clive S on topic RPI 4 + Mesa 7c80 VFD Spindle Config
You have
try
Time to create page: 0.246 seconds
