Shift Key jogging speed
25 Feb 2021 05:18 #200058
by turbostew
Shift Key jogging speed was created by turbostew
I wish there were a way to set the fast jog (shift+arrow) independant from slow jog or at least hack in a value for like 5 to 1 ration vs the 2 to 1 we have now. Anyone done this?
25 Feb 2021 05:25 #200059
Replied by cmorley on topic Shift Key jogging speed
What screen?
27 Feb 2021 16:44 - 27 Feb 2021 17:27 #200309
by turbostew
Replied by turbostew on topic Shift Key jogging speed
Manual mode jogging with keyboard.
I found the speed mult in code and changed it. I changed it so "fast" (meaning shift key) is the jog feed rate and "slow" is divide "fast" by 5 (was "slow" was jog speed and "fast" was X2). That way the jog speed slider can be maxed out at machine limits and not "fast" be something less. IMHO the original way the top half of the slider was sort of wasted.
What would be nice is if the jog speed could be independently set for each axis. My Z is very slow on the router, least travel, the most precise, and the easiest to crash. I would like to set it up to jog much slower than the big long 10ft Y axis jogging at 800IPM....
Last edit: 27 Feb 2021 17:27 by turbostew.
27 Feb 2021 16:59 #200310
Well nothing can happen if you don't answer the question.
Each screen does jogging it's own way.
Anyways you seemed to get what you wanted - that's the power of open source!
27 Feb 2021 17:24 - 27 Feb 2021 17:26 #200313
by turbostew
Sorry, Main Manual Mode screen I guess. I thought KB jogging was the same in all screens that allow it. My Linux machine is at the shop so I am going off memory....
Last edit: 27 Feb 2021 17:26 by turbostew.
27 Feb 2021 17:39 #200316
Sorry maybe I miss communicated.
I was looking for 'AXIS', 'Gmoccaapy' etc or if you quote the file name you modified.
Chris
Chris
27 Feb 2021 22:39 #200357
by tacklem60
Replied by tacklem60 on topic Shift Key jogging speed
Not to hijack the OP thread here, but i have been wondering the exact same thing in QTdragon. Shift+Jog doubles the slider jog rate which is certainly useful, however, im used to this functionality in Gmoccapy where shift+jog always gave me full rapid speed.
If there was a way to either set shift to always give full rapid or change it to a much higher number like 10x so it usually results in full rapid that would be great
27 Feb 2021 22:53 #200359
In qtDragon you would need to change the handler file (copy it in your config folder first)
then in this function :
change the rate = rate * 2 to
rate = INFO.MAX_TRAJ_VELOCITY/60
for max velocity - should do it.
def kb_jog(self, state, joint, direction, fast = False, linear = True):
if not STATUS.is_man_mode() or not STATUS.machine_is_on():
self.add_status('Machine must be ON and in Manual mode to jog')
return
if linear:
distance = STATUS.get_jog_increment()
rate = STATUS.get_jograte()/60
else:
distance = STATUS.get_jog_increment_angular()
rate = STATUS.get_jograte_angular()/60
if state:
if fast:
rate = rate * 2
ACTION.JOG(joint, direction, rate, distance)
else:
ACTION.JOG(joint, 0, 0, 0)
The following user(s) said Thank You: tacklem60
28 Feb 2021 01:50 #200363
by tacklem60
Another perfect reply. I also was able to set my "slow" jog push button to 1/20 of the slider speed. I can now jog around at 250ipm (my rapid speed) by holding shift, release shift and move around at 60ipm to get close with my Haimer to set my WCS then hit slow and drop down to 3ipm to easily jog the rest of the way and sit my zero positions.
Basically the only 3 speeds I ever use on the machine all done without ever having to actually adjust jog speed. Such a simple quality of life improvement for the smallest of changes.
28 Feb 2021 06:11 #200373
excellent. I'm happy the customization ability of qtvcp has become utilized successfully by people like yourself. Thank you for the feeedback.
Chris
Chris
Time to create page: 0.164 seconds
