versin of linuxcnc
- gholamrezazade
01 Mar 2021 07:29 #200510
by gholamrezazade
versin of linuxcnc was created by gholamrezazade
hello ; I was instal the ubunto linux but i not know what the version of linuxcnc software can be installed
01 Mar 2021 09:26 - 01 Mar 2021 09:27 #200517
Replied by Aciera on topic versin of linuxcnc
Note that you need a real-time kernel to run linuxcnc.
Easiest is to use the offical Debian Buster ISO:
linuxcnc.org/downloads/
Then you could also try LinuxMint which is based on ubuntu if you need better driver support. But this is a bit more involved:
forum.linuxcnc.org/9-installing-linuxcnc...-easy-install#175816
Last edit: 01 Mar 2021 09:27 by Aciera.
The following user(s) said Thank You: gholamrezazade
- gholamrezazade
01 Mar 2021 17:32 #200714
by gholamrezazade
Replied by gholamrezazade on topic versin of linuxcnc
thanks when i instal the linux debian ;linuxcnc is automatically installed?
01 Mar 2021 18:01 #200715
No, linuxcnc is not installed with regular debian. The realtime kernel is also not installed with a regular debian installation.
The official ISO is debian with a realtime kernel and linuxcnc preinstalled. That's why it's the recommended method.
Time to create page: 0.183 seconds
