hello all, beginner here with some issues with linux cnc
14 Mar 2021 08:15 #202194
by santiagoe
ok this is my first time with linux and the cnc world, currently building a PrintNC my first diy proyect, i was having issues with the wifi and mesa 7i96 at the same time but i fixed that thanks to a thread in this forum, now i am facing some difficulties trying to run linuxcnc properly.
first i am trying to control the speed of the spindle through a USB-rs485 adapter connected between the Rpi4 and a huanyang vfd, to do that i followed this thread in the project wiki wiki.printnc.info/en/controllers/linuxcnc/vfd , so i added some commands to the custom.hal and custom_postgui.hal(i followed all the steps) then when i try to execute linuxcnc i get the following
debug file information:
custom_postgui.hal:5: Pin 'gmoccapy.spindle_feedback_bar' does not exist
2768
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
after that if i comment that line, i get the following error
Debug file information:
custom_postgui.hal:6: Pin 'gmoccapy.spindle_at_speed_led' does not exist
3078
so i think i am missing something in my GUI? so well i comment those two lines and then i get two errors like this
./vfd.hal:5: Pin 'spindle.0.speed-out' was already linked to signal 'spindle-vel-cmd-rpm'
3709
with that line and this one ``spindle-enable <= spindle.0.on`` so again i comment those lines in the main hal file and this time linuxcnc executes successfully, but when i try to start and run the spindle it only goes up to 10Hz, i tested the vfd with the knob and it worked fine and the spindle ran flawlessly up to 400Hz, i tried to fix that but was not successful so here i am,those are the three issues i have so far, the spindle speed issue and the gui missing pins(?) and the commands that are double linked, also i used the pncconf wizard and already have the motors moving, thank you for taking the time to read this and hopefully you can help me.
2768
3078
3709
14 Mar 2021 08:18 #202195
by santiagoe
Replied by santiagoe on topic hello all, beginner here with some issues with linux cnc
forgot to mention that i changed the parameters in the vfd to work correctly
15 Mar 2021 06:26 #202308
by newbynobi
Replied by newbynobi on topic hello all, beginner here with some issues with linux cnc
Please try to enable again the line gmoccapy.spindle_at_speed, as that one should work.
If it does let's take the next step and enable the feedback bar.
IMHO that error was caused as consequence of the vfd error.
If enabling the spindle at spped line in postgui Hal does throw errors, please post the complete output from the terminal.
Norbert
Norbert
16 Mar 2021 07:36 #202455
by santiagoe
thank you for your response, tbh not sure if i followed you correctly but i just enabled both lines of the custom_postgui.hal, one at a time and at the same time and still got the same errors so i am lost here, i am going to upload the report file not sure if that is what you need as i am not sure what output from the terminal is, if that file is not useful please tell me how can i get what you need.
16 Mar 2021 07:38 #202456
by santiagoe
.Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/pi/linuxcnc/configs/santiPNC'
Machine configuration file is 'santiPNC.ini'
INIFILE=/home/pi/linuxcnc/configs/santiPNC/santiPNC.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./santiPNC.hal
Running HAL shutdown script
custom_postgui.hal:4: Pin 'gmoccapy.spindle_at_speed_led' does not exist
6281
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Tue 16 Mar 2021 02:27:50 AM CDT
UTC Date: Tue 16 Mar 2021 07:27:50 AM UTC
this program: /usr/bin/linuxcnc_info
uptime: 02:27:50 up 2 days, 12:54, 2 users, load average: 0.57, 0.94, 1.43
lsb_release -sa: Raspbian Raspbian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/pi/linuxcnc/configs/santiPNC
USER: pi
LOGNAME: pi
HOME: /home/pi
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: LXDE-pi
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/pi/linuxcnc/configs/santiPNC/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: linuxcnc
kernel-name -s: Linux
kernel-vers -v: #4 SMP PREEMPT RT Thu Apr 30 22:00:15 CDT 2020
machine -m: armv7l
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:69:AF:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=f8afa9f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes isolcpus=3 idle=poll rootwait quiet splash plymouth.ignore-serial-consoles
model name: ARMv7 Processor rev 3 (v7l)
cores:
cpu MHz:
parport:
serial:
Versions:
gcc: gcc (Raspbian 8.3.0-6+rpi1) 8.3.0
python: Python 2.7.16
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYZ
6281
pastebin.com
USER: pi
LOGNAME: pi
HOME: /home/pi
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: LXDE-pi
uname items:
machine -m: armv7l
/proc items:
cores:
cpu MHz:
parport:
serial:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
16 Mar 2021 08:14 - 16 Mar 2021 08:23 #202459
Replied by Aciera on topic hello all, beginner here with some issues with linux cnc
I think the problem is this in the second line of your 'santiPNC.hal':
This tells LCNC to load the postgui_call_list.hal before the GUI has been loaded and that is why the gmoccapy pins do not yet exist.
So delete that line.
Note that this line in the [HAL] section of your INI tells LCNC to load your postgui_call_list.hal automatically once the GUI has been loaded:
So you don't need to load it manually.
[edit]
Just noticed that you have this in your 'postgui_call_list.hal':
I'm not sure you need that to be loaded after the GUI. If it needs to be loaded earlier you could move it to the [HAL] section of your INI:
source postgui_call_list.hal
POSTGUI_HALFILE = postgui_call_list.hal
[edit]
source pyvcp_options.hal
[HAL]
HALUI = halui
HALFILE = santiPNC.hal
HALFILE = pyvcp_options.hal
HALFILE = custom.hal
SHUTDOWN = shutdown.hal
Last edit: 16 Mar 2021 08:23 by Aciera.
The following user(s) said Thank You: santiagoe
16 Mar 2021 14:34 #202481
by newbynobi
@Aciera,
thanks for your attention, I must have overlooked that one. Your solution should solve the problem.
Norbert
Norbert
16 Mar 2021 19:26 #202505
by santiagoe
hi thanks for your answer, with that i was able to get the led and feedback bar working in gmoccapy also i commented the pyvcp lines so that does not show up anymore, thank you very much but i am still unable to set the speed in the vfd, it still starts at 300 rpm but it does not let me go faster, i have not found the line to configure that, thanks again
16 Mar 2021 19:53 #202508
I'm not familiar with that vfd component.
Are there any commands that work with your vfd using your current config?
16 Mar 2021 20:00 #202509
by santiagoe
the only way i found to go higher was to set the starting rpm to 10000 but that is the limit, i think that is not the right way to do it, i also tried changing the spindle max output in the ini file but that is not working
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000.0
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
Time to create page: 0.409 seconds
