- General
- General LinuxCNC Questions
- pmCirclePoint function in c\linuxcnc\src\libnml\posemath\posemath.c
17 Mar 2021 04:53 #202558
by mil818
pmCirclePoint() returns the point at the given angle along
the circle. If the circle is a helix or spiral or combination, the
point will include interpolation off the actual circle.
int pmCirclePoint(PmCircle const * const circle, double angle, PmCartesian * const point)
PmCartesian par, perp;
double scale;
#ifdef PM_DEBUG
if (0 == circle || 0 == point) {
#ifdef PM_PRINT_ERROR
pmPrintError
("error: pmCirclePoint circle or point pointer is null\n");
#endif
return pmErrno = PM_ERR;
#endif
/* compute components rel to center */
pmCartScalMult(&circle->rTan, cos(angle), &par);
pmCartScalMult(&circle->rPerp, sin(angle), &perp);
/* add to get radius vector rel to center */
pmCartCartAdd(&par, &perp, point);
/* get scale for spiral, helix interpolation */
if (circle->angle == 0.0) {
pmPrintError("error: pmCirclePoint angle is zero\n");
#endif
return pmErrno = PM_DIV_ERR;
scale = angle / circle->angle;
/* add scaled vector in radial dir for spiral */
pmCartUnit(point, &par);
pmCartScalMult(&par, scale * circle->spiral, &par);
pmCartCartAdd(point, &par, point);
/* add scaled vector in helix dir */
pmCartScalMult(&circle->rHelix, scale, &perp);
pmCartCartAdd(point, &perp, point);
/* add to center vector for final result */
pmCartCartAdd(&circle->center, point, point);
return pmErrno = 0;
Question:
For function pmCirclePoint,who can explain it clearly ? it is better that you could draw a figure to us, thank you a lot !
what is theroy ?
what is theroy ?
what is theroy ?
double scale;
#ifdef PM_DEBUG
pmPrintError
#endif
#endif
#endif
return pmErrno = 0;
Question:
what is theroy ?
what is theroy ?
what is theroy ?
18 Mar 2021 01:42 #202697
Replied by andypugh on topic pmCirclePoint function in c\linuxcnc\src\libnml\posemath\posemath.c
LinuxCNC sends position information to the hardware once every mS.
When performing an arc move, that means sending a series of points along the arc as coordinates.
I think that this is what this code is for.
18 Mar 2021 07:51 #202712
by mil818
Replied by mil818 on topic pmCirclePoint function in c\linuxcnc\src\libnml\posemath\posemath.c
there is not exact document or figure to introduce this.A little bit regret.
19 Mar 2021 18:11 #202870
by newbynobi
Replied by newbynobi on topic pmCirclePoint function in c\linuxcnc\src\libnml\posemath\posemath.c
The machine needs X and Y position, as it only can move from point to point.
The Funktion does calculate the X and Y position for a point of a circle and gives that point (X/Y) to the machine that will move to that position.
Explained as simple as possible
Norbert
Norbert
- General
Time to create page: 0.329 seconds
