Proposal : Installing linuxcnc in /opt/ directory
17 Mar 2021 07:24 #202566
by Grotius
Proposal : Installing linuxcnc in /opt/ directory was created by Grotius
Currently working on a debian 11 distro.
Linuxcnc compiled without many problems.
My proposal is to pre-install linuxcnc in the /opt/ directory of the distro with a .deb package.
Normally when the linuxcnc .deb packages are installed on the system, the linuxcnc files are spread around over the system
directory's. For new linuxcnc users this might be very confusing if they are looking for a file.
And they might get a feeling like searching for a needle in a haystack.
What would be the downside of installing a program in the /opt/ directory ?
18 Mar 2021 01:02 #202690
by 85422776
Replied by 85422776 on topic Proposal : Installing linuxcnc in /opt/ directory
thank you a lot
18 Mar 2021 02:07 #202703
Replied by andypugh on topic Proposal : Installing linuxcnc in /opt/ directory
I think that the files are put in the "usual" Debian locations.
Looking at my own machine, the only package that has put itself in /opt is Google Chrome.
I don't think it is a bad idea, but I do see it being quite a bit or work for a benefit of dubious magnitude.
Would docs and manpages go in opt? would man find them there?
18 Mar 2021 08:03 #202713
by Grotius
Replied by Grotius on topic Proposal : Installing linuxcnc in /opt/ directory
Following en.wikipedia.org/wiki/Filesystem_Hierarchy_Standard linuxcnc should be in the /opt/ folder.
When i read acros several fora, the advise is to store program's into the /opt/ folder.
Most of the linux program's don't follow this rule, and i think window's does it correctly with the "program files" folder.
The linuxcnc top folder of the deb package is then unpacked in : /opt/linuxcnc
The rest of the linuxcnc files are in /opt/linuxcnc/ ..
The sub-hierarchy of the linuxcnc file system can stay the same to avoid useless work.
I already made and installed a .deb package this way. It goes well.
If you look at the current linuxcnc/debian directory, this is at the moment a cruel place to look.
I think 3 files over there is enough to build a package.
18 Mar 2021 09:02 #202715
I think that this proposal belongs on the developers mailing list. Are you subscribed?
18 Mar 2021 09:15 #202717
by arvidb
Replied by arvidb on topic Proposal : Installing linuxcnc in /opt/ directory
As I understand it /opt is for packages that
1) Does not otherwise conform to the File Hierarchy Standard
and
2) Is not managed by the distro package management system (e.g. apt).
Manually built packages that otherwise follow the FHS, but that doesn't use the distribution's package managing system, should be installed under /usr/local (typically these kinds of packages are installed using 'make install').
Packages that are part of the distro, i.e. that's installed and managed with 'apt' on debian systems, should use the standard directories (/usr).
In my view, /opt is more for packages that are delivered as proprietary blobs. E.g. development environments that's been ported from Windows to Linux and thus doesn't conform at all to the Linux ecosystem.
I'm not sure I understand the problem described in the original post. Can you give a specific example of a situation when a file is difficult to find for a new user, and would be more easily found if installed under /opt?
and
18 Mar 2021 18:13 - 18 Mar 2021 18:26 #202751
by Grotius
Yes, they can be there, with a launcher into the system menu as it is already.
No not subscribed.
But i will take care of the code. Will make a tiny script to get it that way.
/etc is referred to as the etcetera directory,[4] as this directory historically held everything that did not belong elsewhere
I think that is not really the case. The /opt/ folder is as all system folders involved for apt.
Yes, ported windows program's are in a good place at /opt/
Linuxcnc is spread around in 15 folders over your filesystem. If you are a developper, it's a different story, then you already work
from one dir. It is almost impossible to work with pleasure with a program that is spread around over 15 system folders. And after a stepconfig wizzard, you get more folders for free in your home dir.
In linux you are free to add system folders. But my proposal is to let linuxcnc join the /opt/ folder.
On sourceforce i provided 2 other linux programs.
One of them works with a python coded youtube-dl, that is stored in the bin folder between
all imporant system bash scripts. I think that's not really clever.
In /opt/ making a export path to the /bin/ is oke for me. It results in a cleaner software environment.
I am in the mood for a positive feedback and conversation. Just escaped from a system bug in the live-build software.
Ahh men, these bash scripts are cruel freubalized fragments of code.
No not subscribed.
Last edit: 18 Mar 2021 18:26 by Grotius.
18 Mar 2021 20:02 - 18 Mar 2021 20:06 #202758
by arvidb
Yep, bash scripts are... not pleasant! I have spent a fair share of time with them as well and I feel your pain!
I'm sorry I cannot give positive feedback to your proposal, but conversation we can have!
I realise that the File Hierarchy Standard can seem weird, especially if you come from a Windows environment, but looking deeper it's actually quite clever: Looking for a binary? Then look under /usr/bin! Looking for some architecture-independent data file, like a man page or font file? Then look under /usr/share ("share" since these files are shared between different cpu architectures). Looking for a configuration file? Then look under /etc ("etc" for, as you said, etcetera - this was apparently named before device files were split to /dev, variable files to /var and so on, and the name stuck, perhaps unfortunate).
It seems to me that it is easier to look in a standardized place for a file, rather than having to learn a completely custom folder tree for each and every application?
The one thing that I find weird about linuxcnc's install paths is the config files located in ~/linuxcnc! Typically these would be under /etc/linuxcnc/, or possibly, if linuxcnc ran as its own user, under /home/linuxcnc/configs/ or something like that.
BTW, looking at the FHS standard , even packages installed under /opt are supposed to have their configuration files under /etc/opt/. And I guess kernel modules would have to be installed under /lib/modules/?
This should probably be installed into /usr/local/bin/? Or possibly /usr/bin/ (" Most user commands "), if installed using the package manager. It most likely should not go into /bin/ (" Essential user command binaries ").One of them works with a python coded youtube-dl, that is stored in the bin folder between
Last edit: 18 Mar 2021 20:06 by arvidb. Reason: Spelling
19 Mar 2021 01:08 #202798
This _might_ be because the config files are intended to be edited by the user, without having administrator privileges?The one thing that I find weird about linuxcnc's install paths is the config files located in ~/linuxcnc! Typically these would be under /etc/linuxcnc/, or possibly, if linuxcnc ran as its own user, under /home/linuxcnc/configs/ or something like that.
19 Mar 2021 06:12 #202806
by newbynobi
Replied by newbynobi on topic Proposal : Installing linuxcnc in /opt/ directory
I have two questions:
- do normal user need to edit linuxcnc files, or look into them? (not the machine config files)
IMHO: not, so he will not care about the location of the file. The only files he will need to edit are in his home directory under linuxcnc, so he will find them quick and he will be able to edit them.
- How does a developer work?
I am working exclusively from a rip environment and I have my linuxcnc-dev in my home dir, so I find any file I am looking for.
So the last question would be:
- Do we / the user will have a real benefit of implementing a new file herachy?
As I do interpret the Linux file system, we are mostly fine and the reason not having the config files in the "correct" place is well known. IMHO the effort we need to put in to replace every Dokumentation and the questions from users to be answered "I do not have that file mentioned in the WIKI" etc. is too hight compared to the benefit. We have just in relation to python 3 a lot of work to do, so let us check this side.
Norbert
Norbert
Time to create page: 0.107 seconds
