Where to read about more of hm2_7i95.0.stepgen.00.counts
19 Mar 2021 17:45 #202864
by suraj9735
I see the pins information in Hal Configuration window. My hm2_7i95.0.stepgen.00.counts fluctuations from -5 to 5. I don't know what does it mean! This is the similar case with other pins too, I don't understand their meaning. So, I would like to read more about those pins definition.
Where to read for pin /signal/parameters definition?
19 Mar 2021 21:27 #202896
by Benb
Replied by Benb on topic Where to read about more of hm2_7i95.0.stepgen.00.counts
You need to do some reading, start with docs in this link
linuxcnc.org/docs/2.8/html/
Next link 7i95 user manual
www.mesanet.com/pdf/parallel/7i95man.pdf
and this link is pcconfig wizard, I recommend you load the program and practice setting up 7i95
linuxcnc.org/docs/2.8/html/config/pncconf.html
At beginning learning LCNC seem difficult. However, if you persist in short time you will be able to configure basic system. Like everything else in life, practice and persistence makes you perfect.
The following user(s) said Thank You: suraj9735
19 Mar 2021 21:27 #202897
Replied by PCW on topic Where to read about more of hm2_7i95.0.stepgen.00.counts
man hostmot2
Also if you have a oscillation in these numbers when not moving
it indicates a tuning issue (probably the PID's P set too high)
Time to create page: 0.142 seconds
