Mesa card emulation in microcontroller
- nickom44
21 Mar 2021 19:50 #203148
by nickom44
Replied by nickom44 on topic Mesa card emulation in microcontroller
Thanks for the link, looks promising
- Thank you received: 4636
21 Mar 2021 23:34 #203172
Replied by andypugh on topic Mesa card emulation in microcontroller
The STMBL Servo drives also act like Mesa devices. In that case they are a Mesa Smart-serial device, and use an STM32 microcontroller.
This means that you can send motor positions as a floating-point number on an all-digital link, and get the actual position back in to HAL in the same way.
- nickom44
22 Mar 2021 10:16 #203221
by nickom44
Interesting, I must admit I don't really understand the serial device part, I assumed this was for a serial device out of the Mesa card to other peripherals.
- nickom44
22 Mar 2021 21:04 #203295
by nickom44
Hi andypugh,
Just re-read your post after reading a bit more about the serial interface, does the servo connect over ethernet, and is it set up as a mesa device?
23 Mar 2021 00:57 #203325
Sorry, I am probably confusing things,
The STMBL contains an STM32 and plugs in to a Mesa FPGA card just like a Mesa Smart-Serial card. In fact as far as the system is concerned it is a normal smart-serial card.
I think that the smart-serial cards from Mesa use a dsPIC rather than a µP like the STM32.
- nickom44
23 Mar 2021 08:37 #203362
by nickom44
Yeah, I think I guessed correctly, smartserial allows peripherals connected to a Mesa to be controlled by LCNC.
I'm interested in getting LCNC to communicate with an STM32 as if it was the FPGA, DOIT commands etc.
- kwarup
- Thank you received: 9
25 Mar 2021 15:15 #203622
by kwarup
Replied by kwarup on topic Mesa card emulation in microcontroller
See this..
github.com/mardini1974/EMC-2-Arduino
Time to create page: 0.558 seconds
