Emco compact 5 cnc (not pc)
23 Mar 2021 10:59 #203378
by xcoopsx
Emco compact 5 cnc (not pc) was created by xcoopsx
Hi all, I have the above machine, i have seen the pc version running with linuxcnc but not my mk4 ver, Will this work via serial connection - i am using usb to serial adaptor at present. This also has 6 position turret, is there many mods to get this to work cheers. Thanks:)
23 Mar 2021 15:09 - 23 Mar 2021 15:09 #203399
by Aaroncnc
Replied by Aaroncnc on topic Emco compact 5 cnc (not pc)
I did a retrofit of my emco mill.
I found that there was no way to use the built in controller and the serial communication.
I had to replace the main controller with something linuxCNC supported.
For more emco specific info you might want to look here Emco CNC user group
All you need is a PC that has a parallel port and a breakout board breakout board
Or a PC with ethernet and a mesa card. 7I92 This card will still need the break out board above but removes the trouble of finding a old pc with the right ports and finding one that has good latency to support the real time functions.
In theory you could possibly code a control system and make it work with linuxCNC but that task was out of my ability. It was much faster and reliable to just swap out the main control board.
In my system i still use the stock VFD and motor drivers, endstops, and switches,
Last edit: 23 Mar 2021 15:09 by Aaroncnc.
23 Mar 2021 18:12 #203414
by xcoopsx
Replied by xcoopsx on topic Emco compact 5 cnc (not pc)
Thankyou i will head there and do some more reading cheers.
Time to create page: 0.114 seconds
