DNC (or other direct input) into LinuxCNC
- robertspark
- Thank you received: 216
31 Mar 2021 09:47 #204196
by robertspark
DNC (or other direct input) into LinuxCNC was created by robertspark
This is going to be a bit of an oddball question (I did do a search on DNC on the forum).
Is there a way to directly control linuxcnc from an external programme? kind of link DNC?
I ask this because I use lightburn lightburnsoftware.com/ (on occasion) and although it can output a DXF for further post processing (by sheetcam) it can also ouput gcode (just not quite correctly formatted for linuxcnc [it uses M106 for laser control as per GRBL / marlin?]
But it can also directly interface with some laser DSP's..... (via USB).
I ws wondering if there was a way that lightburn could directly communicate with LinuxCNC?
(I know from my past with sheetcam + Mach3 + scanything that sheetcam had a means to directly interface with Mach3).
This is just a shooting the breeze question to see if its been discussed before or there is a way that I can go and read up on or look at what someone else has done.
31 Mar 2021 18:56 #204260
by aleksamc
Replied by aleksamc on topic DNC (or other direct input) into LinuxCNC
Look for
axis-remote
, I think it will help you.
The following user(s) said Thank You: robertspark
- robertspark
31 Mar 2021 22:21 #204322
by robertspark
Replied by robertspark on topic DNC (or other direct input) into LinuxCNC
Thanks for the pointer, much appreciated
Time to create page: 0.134 seconds
