'module' object has no attribute 'get_value'
09 Apr 2021 13:23 #205429
by elisa
'module' object has no attribute 'get_value' was created by elisa
Hi to all,
I have a problem wiht the command "hal.get_value", when I run the python script I get this error:
in <module> x= hal.get_value("x-pos-fb")
AttributeError: 'module' object has no attribute 'get_value'
Please write soon!
Please write soon!
09 Apr 2021 21:55 #205484
Replied by andypugh on topic 'module' object has no attribute 'get_value'
I thought you reported that this was fixed?
10 Apr 2021 04:57 #205504
Replied by cmorley on topic 'module' object has no attribute 'get_value'
can you post all the code you used?
There are other commands that need to be called before that works.
10 Apr 2021 07:25 #205508
by elisa
Replied by elisa on topic 'module' object has no attribute 'get_value'
There are my python code and the postgui hal.
However, I may have figured out what the problem is. The "hal.get_value ()" command works in LinuxCNC version 2.8.1 but not 2.7.14. I guess this command only works in newer versions, doesn't it?
10 Apr 2021 08:19 #205511
by elisa
However, I found the "s.actual_position" command in the documentation which also seems to work in version 2.7.14. If I understand correctly, this command reads the linuxcnc status and I can update the "current joint position" with the s.poll () command.
I will write a post to help everyone who has problems with these things!
Thank you all!
Thank you all!
10 Apr 2021 21:51 #205572
Why are you using 2.7.14? 2.8 has been released for more than 6 months.
What kind of machine are you working with? 2.8 is significantly better for non-cartesian machines.
11 Apr 2021 07:26 #205604
by elisa
I am working with a 5-DOF robotic arm.
In the lab I'm working in, they use the old version because they have had problems installing the new one.
I agree with you, I will stress to my colleagues to update it to the latest version.
However, I'm afraid the .ini file won't work. In fact, I read in the wiki that in case of updating the .ini file must also be updated but there are no details on how to do it. Do you have any suggestions?
Thank you.
Thank you.
11 Apr 2021 08:19 #205610
But, in general, the "update_ini" script should run automatically and make the required changes for you.
The major changes in 2.8x from 2.7x were to better support robots and gantries.I am working with a 5-DOF robotic arm.
The required changes are documented in section 3 of "Updating Linuxcnc" in the docs.However, I'm afraid the .ini file won't work. In fact, I read in the wiki that in case of updating the .ini file must also be updated but there are no details on how to do it. Do you have any suggestions?
The following user(s) said Thank You: elisa
Time to create page: 0.191 seconds
