VFD Feedback
11 Apr 2021 14:48 #205643
by mb_cnc
VFD Feedback was created by mb_cnc
Hello, I'm wondering what is the best approach is to read/display the spindles current voltage, amps, rpm, status and error codes?
linuxcnc 2.9
Mesa 7i76e - VFD connected to TB4
Delta VFD-E
SilverDragon
thanks
linuxcnc 2.9
Delta VFD-E
SilverDragon
thanks
11 Apr 2021 15:35 #205646
Replied by cmorley on topic VFD Feedback
There is a component for the delta VFD-b:
linuxcnc.org/docs/2.8/html/man/man1/vfdb_vfd.1.html
i don't know if it will work with your VFD.
11 Apr 2021 17:02 #205654
by mb_cnc
Replied by mb_cnc on topic VFD Feedback
Thank you but I'm not sure of the hardware connection for that option? Would that be using the VFD's RS-485 interface and a sserial signal converter for the 7i76e?
thanks
thanks
11 Apr 2021 18:08 #205665
yes rs485
typically I think you would use the rs232 port or USB port with a converter.
Time to create page: 0.231 seconds
