Home Limit Switch
- Jeff_in_Wa
- Thank you received: 5
26 Apr 2021 04:03 #207070
by Jeff_in_Wa
Home Limit Switch was created by Jeff_in_Wa
When I home my cnc router, when the Y Axis's hit their switches, they come off and go back to the switch as expected. Then the switch gets smashed and the machine stops. It's not trying to move any further.
Here is the code being used on one Y axis
[AXIS_Y]
MAX_VELOCITY = 150.0
MAX_ACCELERATION = 200
MIN_LIMIT = -0.001
MAX_LIMIT = 838
[JOINT_1]
TYPE = LINEAR
HOME = -12
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
STEPGEN_MAXACCEL = 220
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 30
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
[AXIS_Y]
MIN_LIMIT = -0.001
MAX_LIMIT = 838
[JOINT_1]
TYPE = LINEAR
HOME = -12
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
- Michael
- Thank you received: 59
26 Apr 2021 04:18 - 26 Apr 2021 04:24 #207071
by Michael
Replied by Michael on topic Home Limit Switch
Easy solution is to switch;
HOME = -12
To
HOME = 12
You have the machine going to this location for the home switch.
Then ask it to go to
HOME = -12
When complete, which makes it hit the switch. HOME is the location the axis moves after the sequence is complete. I would also change:
MIN_LIMIT = -0.001
To be farther away from your home
You want to make sure the axis moves far enough off the axis to clear the throw of the switch it self and to compensate for any slop or chips that may be present. Switch
MIN_LIMIT = -0.001
To
MIN_LIMIT = 1.000
Assuming this is all in mm
HOME = -12
To
HOME = 12
HOME = -12
MIN_LIMIT = -0.001
MIN_LIMIT = -0.001
To
MIN_LIMIT = 1.000
Last edit: 26 Apr 2021 04:24 by Michael.
- tinah
26 Apr 2021 11:45 #207101
by tinah
Replied by tinah on topic Home Limit Switch
i'll try this config
The following user(s) said Thank You: Jeff_in_Wa
- Jeff_in_Wa
26 Apr 2021 15:43 #207131
by Jeff_in_Wa
Replied by Jeff_in_Wa on topic Home Limit Switch
Thank you for taking the time to help me with this. After reading your reply, I realized how I should have seen this.
I wonder if my Z is backwards...
When I home all, the Z goes up, hits the switch and back off of it by 12mm's
But in the settings, I have home set to -12
Based on what you have told me above, something seems off in my thinking. If I understand you correctly, Home should be 0,0 and when the axis's move off of their respective switches, the machine coordinates should be moving into positive numbers.
I think what's throwing me is I had an MPCNC and I homed to the rear right corner with that as this one. But when I moved off the switches, I was always in the negative.
I will try your suggestion. It makes total sense to me. Thanks a ton!
- Clive S
- Thank you received: 486
26 Apr 2021 16:05 #207134
by Clive S
Replied by Clive S on topic Home Limit Switch
Above you were talking about Y Now you are talking about Z
If you are talking about Z then it is common for Z to be going -ve when going down. So -12 should send the Z down 12 units
- Jeff_in_Wa
26 Apr 2021 16:43 #207140
by Jeff_in_Wa
Thanks Clive. The Y's are working now. But I know there is still something wrong with my thinking about the machine coordinates.
When I push the down arrow on my keyboard, the Y axis moves to the back. So I know that I've got the Y motors wired in the wrong direction. Do I change the sign on Home_Search_Vel to have the gantry move towards the back after?
I think this issue is what made me think I had a problem with the Z
- Clive S
26 Apr 2021 18:27 #207144
by Clive S
This all depends where the switches are located front or back I take it the Y is the gantry if so and you have two motors then the sequence has to be a -ve same number on both joints (motors)
You can change the direction of the motors by make the SCALE=xxxx -ve but then you have to change all the rest below
re this:
[JOINT_1]
HOME = -12 .. this will be the final home postion
HOME_OFFSET = 0.000000 .. this is to square the gantry ie 0.5
HOME_SEARCH_VEL = 3 ..If you cange it to -ve it will search in the opposite direction 0
HOME_LATCH_VEL = 5 .. as above
HOME_SEQUENCE = -1 .. this has to be -ve for gantry squaring
When I push the down arrow on my keyboard, the Y axis moves to the back. So I know that I've got the Y motors wired in the wrong direction. Do I change the sign the same as on Home_Search_Vel to have the gantry move towards the back after?
re this:
[JOINT_1]
- Jeff_in_Wa
26 Apr 2021 18:34 #207146
by Jeff_in_Wa
When I home now, all joints home properly, move off of the switch 12mm's. Perfect!
But then I'm getting "Exceeded Negative Soft Limit (-0.00100) on joint 1 X
And "Exceeded Negative Soft Limit (-0.00100) on joint 2 Y's
I can see why I'm getting the error as "Home" value is a negative value. What I can't figure out is why the machine is homing properly in spite of it being wrong.
Home is wanted to be at the right / rear of my cnc router
Here are my Y settings:
[AXIS_Y]
MIN_LIMIT = -0.001
MAX_LIMIT = 838
[JOINT_1]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_SEARCH_VEL = -30
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
#HOME_SEARCH_VEL = 0
#HOME_LATCH_VEL = 0
#HOME_USE_INDEX = NO
#HOME_SEQUENCE = -1
[JOINT_2]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
#HOME_LATCH_VEL = 0
#HOME_SEQUENCE = -1
Thanks for any assistance.
[AXIS_Y]
MIN_LIMIT = -0.001
MAX_LIMIT = 838
[JOINT_1]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
#HOME_LATCH_VEL = 0
#HOME_SEQUENCE = -1
[JOINT_2]
TYPE = LINEAR
HOME = -12.0
MIN_LIMIT = -0.001
MAX_LIMIT = 838
MAX_VELOCITY = 200
SCALE = -80.0
FERROR = 1
MIN_FERROR = 0.25
HOME_LATCH_VEL = 5
HOME_SEQUENCE = -1
#HOME_LATCH_VEL = 0
#HOME_SEQUENCE = -1
- Thank you received: 7465
26 Apr 2021 18:43 #207148
Replied by tommylight on topic Home Limit Switch
HOME = -12.0
MIN_LIMIT = -0.001
That can not work, home must be a value inside the limits.
Use HOME_OFFSET to move from the switch.
MIN_LIMIT = -0.001
- Jeff_in_Wa
26 Apr 2021 18:50 #207149
by Jeff_in_Wa
Thank you. I will try that.
On my old cnc, home was back right corner as well. But all the numbers on the dro were negative from home. I'm pretty sure this is why I'm struggling with this software.
I'm having to rethink my work area. Am I right in this?
I was told cnc's all use a negative work area.
Time to create page: 0.135 seconds
