- LinuxCNC
- General LinuxCNC Questions
- "Start from line" enforces all tool changes from start to happen...
- mydani
- Thank you received: 9
28 Apr 2021 17:48 #207316
by mydani
"Start from line" enforces all tool changes from start to happen... was created by mydani
...but why?
Regards,
Daniel
Regards,
Daniel
- mydani
30 Apr 2021 08:57 #207435
by mydani
Replied by mydani on topic "Start from line" enforces all tool changes from start to happen...
- bevins
- Thank you received: 338
30 Apr 2021 11:36 #207443
by bevins
You found the elephant behind the tree in the room.
QTPlasmaC got around this issue I think by loading a temp file starting from the line you selected and it does not have these behaviours because it is like loading a new file and starting from scratch. This is amazing and all the other screens should do the same thing and that may fix the issue with run from line and a remap. But I dont know as I havent tried a toolchange remap with QTPlasmac and it may never come up until someone tries to change tools (torch) on a QTPlasmac machine.
I have never had an issue with the run from line in QTPlasmac. It just works everytime.
just ranting..... sorry
Replied by bevins on topic "Start from line" enforces all tool changes from start to happen...
Answer: github.com/LinuxCNC/linuxcnc/issues/246#issuecomment-423049528
- mydani
30 Apr 2021 15:45 #207461
by mydani
All good. I think there are some possibilities to hack-in a skip of remaps in the interpreter in case of ongoing "start from line", or maybe some hack in the remap which exists w/o being a queue-buster, or similar...
Just need to dig into it... *sigh*
- Thank you received: 4636
01 May 2021 21:52 #207578
I disagree. There are too many case like this where a particular screen has a clever workaround for something that should be fixed elsewhere in the code so that it is fixed for every GUI.
Replied by andypugh on topic "Start from line" enforces all tool changes from start to happen...
- cakeslob
- Thank you received: 278
02 May 2021 00:07 #207594
by cakeslob
Replied by cakeslob on topic "Start from line" enforces all tool changes from start to happen...
What kind of lines do you guys run from? This isnt a linuxcnc specific question, im curious how other people use it on other controllers as well. I understand for plasma its a different situation, but for the cnc mill/lathe users, what lines do you run from and what do you expect to happen?
For example, if you start in the middle of a surface profile toolpath and you start on line " g1 x56 y78"
will it move in only x and y until it receives a z move? or does the spindle/coolant/etc start up and it rockets to the correct position? or does it move all 3 axis at once (like 3d diagonal) into position?
I ask, because I've never really started from any other line than a tool change at work or home on linuxcnc, and Ive never had the issue with it cycling through all toolchanges or anything weird/scary, but i only ever start from lines like this, i would start from n24
N24 T24 ( 5/16 FLAT ENDMILL)
M06
G00 G17 G90 G54 X5.7003 Y-4.2403 S4340 M03
G43 H24 Z2. M08 T3
Z.1
G01 Z-.0491 F15.
X5.7024 Y-4.236 F40.
X5.7191 Y-4.2023 Z-.0529
X5.722 Y-4.1929 Z-.054Please Log in or Create an account to join the conversation.
- bevins
02 May 2021 02:01 #207595
by bevins
Normally i would agree with you but since most of these hacks and workarounds stems from using a 40 year old interpreter i dont mind having the gui’s changed individually to get the functionality needed. I have had customers drop linuxcnc because of some of these issues.
- pippin88
- Thank you received: 51
02 May 2021 09:29 #207608
by pippin88
Replied by pippin88 on topic "Start from line" enforces all tool changes from start to happen...
Run from line is not as simple as it first seems
Is the spindle on? Should it be? RPM?
What work offset?
Z height?
Many other complications.
For some GCode it will be easy - starting at a toolchange often will have all the important code like ME, RPM, correct X,Y,Z moves.
But a long file without tool changes won't have those things and starting from the middle may be problematic.
What work offset?
Z height?
- mydani
02 May 2021 18:12 #207663
by mydani
I personally also start from a tool change line, and my cam sets all required parameters afterwards, so no checks at all required.
Call it a "dumb start from line". Combined with a possibility to manually (MDI) preset everything, e.g. G17/.., Fxx, Sxx, M3/4, ... this dumb start from line would be really helpful for the intermediate user.
- LinuxCNC
