Stepper Driver Control With Ethercat
- luke-doyle
29 Apr 2021 21:48 - 29 Apr 2021 21:50 #207415
by luke-doyle
Stepper Driver Control With Ethercat was created by luke-doyle
Hi Guys,
First time posting here... so forgive me if is a question that has an obvious answer!
I am just wondering if anyone has used an Ethercat card to drive the stp and dir pins of a stepper motor driver card. I am aware of a project that uses a Ethercat card (EL7041) to connect to the motor windings directly, however this card lacks the voltage output that is required for my steppers. I imagine a digital output card at 5V would be able to achieve this, but would require a bit of hands on HAL linking! I am able to do this, but any insight from someone that has tried (or achieved) would be appreciated!
The reason I am so keen on using the Ethercat Bus to drive the steppers is that I am using an industrial fanless PC on another project that as well as running the Ethercat Bus, runs some Rexroth Servo Drives running over Ethercat. If I could continue to use the same industrial PC on both machines that would be a big plus.
Thanks in advance,
Luke
Thanks in advance,
Luke
Last edit: 29 Apr 2021 21:50 by luke-doyle.
- Thank you received: 6008
30 Apr 2021 00:12 - 30 Apr 2021 00:12 #207421
Replied by tommylight on topic Stepper Driver Control With Ethercat
No idea, never used anything Ethercat, but just in case you missed it:
Mesa 7i92 or 7i96 or 7i76E or some others. Not Ethercat but ethernet.
Last edit: 30 Apr 2021 00:12 by tommylight. Reason: more info
30 Apr 2021 05:15 - 30 Apr 2021 07:24 #207427
by Hakan
Replied by Hakan on topic Stepper Driver Control With Ethercat
A quick search shows this one www.ethercat.org/en/products/46890720C40...BDBF3D69D0844269.htm that seems to do the trick.
But I would think the best way is to find a ethercat stepper driver. I have just used the rtelligent ect60 that goes up to 80 VDC/6A and there is another, ect86, that goes up to 100VDC/8A. Leadshine has two series of stepper drives that goes up to 100VDC/8A and I am sure there are more.
Last edit: 30 Apr 2021 07:24 by Hakan. Reason: modified some text
Time to create page: 0.132 seconds
