Gets stuck on a G0 line
- ExcessiveO
- Thank you received: 5
30 Apr 2021 01:40 #207425
by ExcessiveO
Gets stuck on a G0 line was created by ExcessiveO
So when I try to run a program, it runs up to N60 and stops. It runs that line but wont move onto the next. There are no errors, the system still responds, and it says there's no distance to go. I have run programs with the same postprocessor(default linuxCNC in Autodesk Inventor) before with no issues.
(1001)
(T4 D=0.25 CR=0. - ZMIN=-0.25 - FLAT END MILL)
N10 G90 G94 G17 G91.1
N15 G20
N20 G53 G0 Z0.
(FACE1)
N25 M9
N30 T4 M6
(.0625)
N35 S5500 M3
N40 G54
N45 M8
N50 G0 X6.0625 Y-2.3589
N55 G43 Z0.6 H4
N60 G0 Z0.2
N65 G1 Z0.025 F17.6
N70 G18 G3 X6.0375 Z0. I-0.025 K0.
N75 G1 X5.9
N80 X0.Please Log in or Create an account to join the conversation.
- Thank you received: 4634
30 Apr 2021 08:01 #207432
Replied by andypugh on topic Gets stuck on a G0 line
Stops at first G1?
Could be the spindle.0.at-speed input.
We seem to be seeing this a lot recently. Can you attach your HAL file? The pin should default to "true" so we should only see a problem if it is attached to something else which isn't working.
- ExcessiveO
30 Apr 2021 16:46 #207466
by ExcessiveO
Replied by ExcessiveO on topic Gets stuck on a G0 line
That could have been the issue, Although I restarted it the next day and it didn't have any problem. The spindle at speed signal changes from true to false when accelerating which seems correct. Intermittent problems are the worst.
01 May 2021 21:54 #207579
The other possibility is feed override set to zero. Pressing the "0" key in Axis will do this. Which is easy to do if you are typing MDI but the MDI window is not actually active.
This would be fixed after a restart.
- Thank you received: 7340
01 May 2021 22:30 #207588
Replied by tommylight on topic Gets stuck on a G0 line
Also pressing the ` ~ key will do that in axis. It is located under the ESC key so often pressed by mistake.
