Axis registers not Zero-ing when homed
02 May 2021 22:58 #207691
by jamby
Axis registers not Zero-ing when homed was created by jamby
Hey
I am just finishing up after installing 2.8 and I noticed that when homed none of the axis registers are zeroing out. Which is what I remember was normal in 2.7. Or am I just suffering another brain fart?
Jim
Jim
02 May 2021 23:29 #207692
by BigJohnT
Replied by BigJohnT on topic Axis registers not Zero-ing when homed
You have some offsets in place...
linuxcnc.org/docs/2.8/html/user/user-con...l#_when_you_are_lost
JT
JT
03 May 2021 15:36 #207728
by jamby
Replied by jamby on topic Axis registers not Zero-ing when homed
BigJohn
Once again the brain thingy gets me. I have a program named Zero that clears all the offsets.
You don't have a write up on how to set up the homing function for a 3 axis bridgeport mill do you?
Thanks again
Jim
Thanks again
Jim
03 May 2021 16:57 #207738
by BigJohnT
No but here is my BP mill axes and joint sections.
JT
[AXIS_X]
MIN_LIMIT = -0.01
MAX_LIMIT = 23.875
MAX_VELOCITY = 3.0
MAX_ACCELERATION = 30.0
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = 3.0
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
P_GAIN = 550
I_GAIN = 0
D_GAIN = 0
FF0 = 0
FF1 = 1.8
FF2 = 0.017
MIN_LIMIT = -0.01
MAX_LIMIT = 23.875
HOME = 0.0
HOME_OFFSET = -0.050
HOME_SEARCH_VEL = -0.25
HOME_LATCH_VEL = -0.01
HOME_FINAL_VEL = 0.1
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
#HOME_USE_INDEX = YES
[AXIS_Y]
MIN_LIMIT = -11.250
MAX_LIMIT = 0.01
MAX_VELOCITY = 3.0
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = 3.0
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
P_GAIN = 550
I_GAIN = 0
D_GAIN = 0
FF0 = 0
FF1 = 1.8
FF2 = 0.02
MIN_LIMIT = -11.250
MAX_LIMIT = 0.01
HOME = 0.0
HOME_OFFSET = 0.050
HOME_SEARCH_VEL = 0.25
HOME_LATCH_VEL = 0.01
HOME_SEQUENCE = 1
[AXIS_Z]
MIN_LIMIT = -4.375
MAX_LIMIT = 0.01
MAX_VELOCITY = 2.0
[JOINT_2]
TYPE = LINEAR
MAX_VELOCITY = 2.0
SCALE = 6000.0
FERROR = 0.05
MIN_FERROR = 0.01
P_GAIN = 500
I_GAIN = 0
D_GAIN = 0
FF0 = 0
FF1 = 1.565
FF2 = 0.02
MIN_LIMIT = -4.375
MAX_LIMIT = 0.01
HOME = 0.0
HOME_OFFSET = 0.050
HOME_SEQUENCE = 0
JT
The following user(s) said Thank You: jamby
03 May 2021 18:29 #207742
by jamby
BigJohnT
Great, that will work for me.
Jim
Jim
Time to create page: 0.387 seconds
