7i92t and 5 axis bob no 0-10v on spindle
05 Feb 2024 10:02 #292498
by 0jw
7i92t and 5 axis bob no 0-10v on spindle was created by 0jw
Hello, I'm not sure what's going on with my spindle setting. I'm using the 7i92t with 7i92_5abobx2d.bit and a cheap 5 axis bob with spindle output set to i/o 000: for pin 1. The relay pin 17 is working as expected but I get 10v on pin 1 with the relay off and no voltage with it on. Giving S commands has no effect with relay off or on. My spindle setting from pncconf were[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 24000.0
So I addedOUTPUT_SCALE = 24000.0
OUTPUT_MIN_LIMIT = 0
OUTPUT_MIN_LIMIT = 24000.0
but this had no noticeable change.
If anyone knows what might be wrong, please let me know
My ini and hal are attached along with the xhc mpg hal.
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
- Thank you received: 5971
05 Feb 2024 12:54 #292505
Replied by tommylight on topic 7i92t and 5 axis bob no 0-10v on spindle
Upload here a picture of the BOB, we have several members here that know all the ins and outs of BOB's just from a picture.
Also, does the voltage change if you set different values for S or speed?
If it ends up being 0V at full speed and 10V at 0/low speed, it is just a matter of inverting the output pin in hal.
05 Feb 2024 14:00 - 05 Feb 2024 14:36 #292513
by 0jw
Replied by 0jw on topic 7i92t and 5 axis bob no 0-10v on spindle
I don't think it's a wiring issue as I was first testing with a multimeder from pin 1 to gnd.
The spindle starts running when the relay is off. So that's a problem. I need to invert that in the sunfar e300 vfd or in hal somehow.
But after using a M3 I can not change the voltage with a S command. After using a M5 command I can not change the voltage as I don't think should be able to. If I disconnect the fwd wire from the vfd it will get 10v when I use a M5 command and 0V with M3 regardless if I use S0 S12000 S24000.
Last edit: 05 Feb 2024 14:36 by 0jw.
05 Feb 2024 14:17 #292516
by 0jw
I have it connected the same as in this diagram.
05 Feb 2024 14:31 #292519
Replied by Aciera on topic 7i92t and 5 axis bob no 0-10v on spindle
I don't see how you have connected the commanded spindle speed in your HAL files. All I see is this:
# --- SPINDLE-CW ---
setp hm2_7i92.0.gpio.000.is_output true
net spindle-cw => hm2_7i92.0.gpio.000.out
# --- SPINDLE-ENABLE ---
setp hm2_7i92.0.gpio.007.is_output true
net spindle-enable => hm2_7i92.0.gpio.007.out
05 Feb 2024 14:52 #292521
by 0jw
Im not sure what its missing. the spindle section was just created through pncconf. Am I just missing a scale component? I wasn't sure what that was and thought it was mabe for dedicated dac converters.
05 Feb 2024 15:13 #292525
Replied by PCW on topic 7i92t and 5 axis bob no 0-10v on spindle
There is no pwm setup or pwm connections in the hal file
and the driver command line has "num_pwmgens=0"
The following user(s) said Thank You: 0jw
05 Feb 2024 15:24 #292527
Seems that you are missing the hal entries for the PWM output.
I'm not familiar with your particular mesa card/ firmware but I would have expected something like in this thread:
forum.linuxcnc.org/24-hal-components/387...tartup-solved#162724
Did you maybe miss the spindle setup in the pncconf tool?
05 Feb 2024 15:29 #292528
I suspect PWM 0 on P2 was not assigned to the spindle in pncconf
I get this:
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_pwmgens=1 num_stepgens=5"
setp [HMOT](CARD0).pwmgen.pwm_frequency 20000
setp [HMOT](CARD0).pwmgen.pdm_frequency 6000000
And this further down:
# ---PWM Generator signals/setup---
setp [HMOT](CARD0).pwmgen.00.output-type 1
setp [HMOT](CARD0).pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
net spindle-output => [HMOT](CARD0).pwmgen.00.value
net spindle-enable => [HMOT](CARD0).pwmgen.00.enable
When I assign PWM 0 to spindle on the P2 tab
I get this:
05 Feb 2024 17:14 #292532
by 0jw
Oh I didn't realize I need a pwm generator in pncconf. In fact I had thought the exact opposite because I need 0-10v. Before in pncconf I had spindle cw on 000: and now I see I can set spindle pwm on 0: not sure it will goto pin 1 but I'll.
Time to create page: 0.131 seconds
