Stepper driver power enable & microstep drop back?
09 Feb 2024 15:22 #292943
by null
Stepper driver power enable & microstep drop back? was created by null
My 'generic stepper driver' manual WARNS that using enable pins [ENBL+ (+5v)] & [ENBL- (ENB)] cause the motor to drop back to the nearest FULL STEP (microstep mode).
Is this drop back a one time event for every enable/disable cycle or might it occur (numerously?) during enabled periods?
- Online
- Thank you received: 5934
09 Feb 2024 15:32 #292945
Replied by tommylight on topic Stepper driver power enable & microstep drop back?
When using microstepping the motor will be often in between magnetic fields, so disabling the drive will normally cause the motor to move to nearest magnetic field.
The maximum error in position will theoretically and practically be 0.9 degree on a 1.8 degree stepper motor.
Usually not an issue due to very often used reductions.
Usually on disable/enable and even then motor must be moved to error again, so it is not cumulative.
The following user(s) said Thank You: null
Time to create page: 0.120 seconds
