Closing GCode files or switching between them?
16 Feb 2024 23:45 - 16 Feb 2024 23:46 #293556
by dmradford
Closing GCode files or switching between them? was created by dmradford
I happen to be running qtdragon_hd, but I assume this to be more of a general question than UI specific.
If I have no file loaded and I'm probing around my stock, it updates very quickly without any issues. However if I load a large file (over 10k lines), after each probe it seems that it has to reload the file to redraw the paths at the new offsets, which dramatically slows down the probing process. I can simply load up an empty gcode file while probing then load up the large file, however this leaves me with a really long list of files in the loaded files dropdown list. Also, when I select a different file from that dropdown, it doesn't appear to actually load it / activate it?
So my question is, is there a way to either:
1) "Close" a file so it's no longer loaded in LinuxCNC without closing LinuxCNC itself
or
2) Switch between loaded files and actually have the newly selected file become active (not just show the gcode in the MDI box)
or
Last edit: 16 Feb 2024 23:46 by dmradford. Reason: Remove accidental emoji
- Thank you received: 5934
16 Feb 2024 23:59 #293559
Replied by tommylight on topic Closing GCode files or switching between them?
What about creating an empty gcode file and open it before probing?
It will probably need two of %
17 Feb 2024 10:52 #293602
by MaHa
Replied by MaHa on topic Closing GCode files or switching between them?
In Axis there is preview control.
linuxcnc.org/docs/stable/html/gui/axis.h...axis:preview-control
At top of gcode file, together with Toggle Skip lines with "/" ,it is easy to control the preview on/off
The comment is case sensitive
/ (AXIS,stop)
/ (AXIS,stop)
Time to create page: 0.063 seconds
