Spindle override encoder not going above 100%
- B.Reilly01
- Thank you received: 13
04 Mar 2024 23:58 #295171
by B.Reilly01
Spindle override encoder not going above 100% was created by B.Reilly01
Just like the title says, I got my overrides set up and I can move the spindle override slider up off 100%, but the override encoder will only go down from 100%. Also, when the spindle override is above 100% and you turn the encoder either direction, it instantly drops to 100%. Any ideas? The spindle is not actually turning, the E-Stop is still "pressed" and I'm on the bench.
05 Mar 2024 00:15 #295172
by spumco
Replied by spumco on topic Spindle override encoder not going above 100%
The SRO and FRO can be clamped by your GUI settings as well as in the INI file.
First thing: check your INI for [DISPLAY] MAX_SPINDLE_OVERRIDE = 1.0 and set it to 1.1 (for 110%) or as you see fit.
- B.Reilly01
05 Mar 2024 01:19 - 05 Mar 2024 01:52 #295174
by B.Reilly01
Replied by B.Reilly01 on topic Spindle override encoder not going above 100%
The INI has it set to 1.5, for the GUI I'm currently in Axis, so maybe it's an Axis setting? Like I said, I can move the slider up, but not with the override knob. The other two sliders behave as expected with the override knob.
edit: In HAL I can see the count go up above 100, but the slider doesn't move.
Last edit: 05 Mar 2024 01:52 by B.Reilly01.
05 Mar 2024 04:43 #295191
by spumco
Can you post your hal and INI files?
- B.Reilly01
05 Mar 2024 20:59 #295258
by B.Reilly01
Certainly, see attached. I think this is all of it.
06 Mar 2024 00:37 #295274
by spumco
I don't see anyting obvious in your config files.
Not that Im' an expert, but I had a look around in in LCNC code and commits and didn't see anything that jumped out.
Can you try using a different GUI - maybe gmoccapy or qtvcp - and see if you get the same behavior? That might narrow it down to Axis or something deeper in LCNC.
- B.Reilly01
06 Mar 2024 01:15 #295278
by B.Reilly01
qtdragon does the same - I wonder if it's because the spindle isn't turning yet and I'm just on the bench
06 Mar 2024 01:36 #295279
by spumco
That's a good idea. Do you have a working physical machine yet to test?
Or perhaps you could bypass the spindle encoder HAL connections and run it as an open-loop simulation. Take it out of estop, 'spin' up the nonexistent spindle and see if the SRO starts working.
- B.Reilly01
06 Mar 2024 02:35 #295282
by B.Reilly01
No running machine yet - and taking out the encoder lines and attempting to "spin" it didn't work, possibly because I can't home the machine.
06 Mar 2024 03:45 #295286
Replied by cmorley on topic Spindle override encoder not going above 100%
MAX_SPINDLE_0_OVERRIDE = 1.500000 is a Qtvcp (QtDragon) setting.
Axis and halui use : MAX_SPINDLE_OVERRIDE = 1.5
So for qtdragon and halui, you would need both settings, for axis only MAX_SPINDLE_OVERRIDE
The following user(s) said Thank You: B.Reilly01
Time to create page: 0.079 seconds
