vismach
- Thank you received: 2177
06 Mar 2024 12:17 - 06 Mar 2024 12:18 #295314
Is this on a recent Debian Bookworm installation?
Replied by Aciera on topic vismach
Seems like there is a problem with your python packages but I'm afraid I don't know how to fix it.ImportError: /usr/lib/python3/dist-packages/_togl.cpython-311-x86_64-linux-gnu.so: undefined symbol: glXDestroyContext
Last edit: 06 Mar 2024 12:18 by Aciera.
- Abdulkareem
06 Mar 2024 13:14 #295317
by Abdulkareem
Replied by Abdulkareem on topic vismach
yes it is the recent debian bookworm installation
- zz912
- Thank you received: 98
06 Mar 2024 20:12 - 06 Mar 2024 20:15 #295344
by zz912
Replied by zz912 on topic vismach
Are spaces allowed in *.stl file names?
Try your configuration only with box first.
Is your *.stl file ascii? It cant be binary.
Last edit: 06 Mar 2024 20:15 by zz912.
07 Mar 2024 10:54 #295389
The problem is with your system/installation since you can't even get the vismach models of the built in configs to run. As long as that does not work there is no point fiddling with your custom vismach simulation.
The following user(s) said Thank You: tommylight, Abdulkareem
- zz912
07 Mar 2024 12:43 #295401
by zz912
If I understood it correctly, built in vismach Abdulkareem can open it. He can not open his vismach.Thank you, it opened the milturn and showed the machine model in the tk screen, now i want to show my machine model
The following user(s) said Thank You: Aciera, Abdulkareem
07 Mar 2024 17:29 #295417
Oops, my appologies, I missed that post, I thought the screenshot showed the millturn config.If I understood it correctly, built in vismach Abdulkareem can open it. He can not open his vismach.
The following user(s) said Thank You: Abdulkareem
07 Mar 2024 17:40 #295419
1. As suggested remove the whitespace in the .stl file names. Also beware that '.STL' is not the same as '.stl'
2. I would recommend to use a 'try' structure so you get some feedback in the terminal
maybe change this:
to something like this:
maybe change this:
base = AsciiSTL(filename="ascii base.STL")
shoulder = AsciiSTL(filename="ascii shoulder.STL")
xaxis = AsciiSTL(filename="X ascii.STL")
yaxis = AsciiSTL(filename="y ascii.STL")
zaxis = AsciiSTL(filename="Z ascii.STL")to something like this:
try:
base = AsciiSTL(filename="ascii_base.STL")
shoulder = AsciiSTL(filename="asci_ shoulder.STL")
xaxis = AsciiSTL(filename="X_ascii.STL")
yaxis = AsciiSTL(filename="y_ascii.STL")
zaxis = AsciiSTL(filename="Z_ascii.STL")
except Exception as error:
print(error)
Time to create page: 0.278 seconds
