vismach issues
- Abdulkareem
07 Mar 2024 01:19 - 07 Mar 2024 01:25 #295371
by Abdulkareem
vismach issues was created by Abdulkareem
I am trying to build my machine in vismach, it works fine till i add my stl file, it shows everything except the stl file, the stl file is ascii not binary. here is the code:
#!/usr/bin/env python3
from vismach import *
import hal
import math
import sys
c = hal.component("simtest")
c.newpin("joint0", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint1", hal.HAL_FLOAT, hal.HAL_IN)
c.newpin("joint2", hal.HAL_FLOAT, hal.HAL_IN)
c.ready()
tooltip = Capture()
toolshape = CylinderZ(30,10,0,10)
toolshape = Color([1,1,0,1],[toolshape])
Aassembly = Collection([toolshape,tooltip])
Aassembly = Translate([Aassembly],0,0,-30)
X=CylinderX(-100,1,100,1)
Y=CylinderY(-100,1,100,1)
Z=CylinderZ(-100,1,100,1)
axes = Collection([X,Y,Z])
axes = Color([0,1,0,1],[axes])
shoulder = AsciiSTL("/home/abdulkareem/linuxcnc/configs/stl/shoulder.stl")
shoulder= Color([1.0,0.5,0.5,1],[shoulder])
Aassembly = Collection([Aassembly,shoulder])
work = Capture()
model = Collection( [Aassembly,work,axes])
main(model , tooltip , work , 100, lat=-75, lon=215)
import hal
import math
import sys
c.ready()
tooltip = Capture()
work = Capture()
Last edit: 07 Mar 2024 01:25 by Abdulkareem.
- Thank you received: 5972
07 Mar 2024 02:19 #295372
Replied by tommylight on topic vismach issues
@Abdul,
stop double posting and stop using the same title for multiple subjects and different topics, you are making it impossible to follow what has been answered and what is going on.
Thank you.
Thank you.
The following user(s) said Thank You: Abdulkareem
- Abdulkareem
07 Mar 2024 11:42 #295395
by Abdulkareem
Replied by Abdulkareem on topic vismach issues
where do i have to post it
07 Mar 2024 12:03 #295398
Where is not important, how is, so use longer tittle that explains what the subject is, and keep stuff relates to the same subject in the same topic.
You already have another topic with this same subject that member Aciera is trying to help you with, keep everything regarding Vismach on that topic.
When using the same title and multiple topics, it is very hard to keep track and even harder when someone else searches for it, and this forum when editing one topic can also change the other, although we got quite good at avoiding his.
In general, post wherever you want and as much as you like/need, we can move stuff around if there is a better place for it, just use longer titles.
Thank you.
Thank you.
The following user(s) said Thank You: zz912
Time to create page: 0.164 seconds
