Another Following Error Thread
09 Mar 2024 20:38 #295537
by darinp
Another Following Error Thread was created by darinp
I am having a NEW issue with following errors.. I have been using the same hal and ini files for quite awhile and now all of the sudden I am getting intermittent following errors on random joints. I have an XYYZ machine with ballscrews and linear rails..
I have looked at many threads and they all seem to indicate consistent errors or erroring out at consistent points.. I am at a total loss.. I can't find any consistency.. I have checked my connections cleaned the ballscrews and linear rails and put WD-40 dry lube on the screw and rails.
Any thoughts or opinions would e much appreciated..
Thanks in advance..
I have attached my hal and ini files.
Thanks in advance..
- Thank you received: 5972
09 Mar 2024 21:35 #295539
Replied by tommylight on topic Another Following Error Thread
Do you get latency warnings when running LinuxCNC?
