Laser min-max power in CAM
25 Mar 2024 21:33 #296773
by santy
Laser min-max power in CAM was created by santy
Hello. How should I manage minimum and maximum power in CAM? What software do you use?
I can use analog to interface with the laser power supply, ok. But how do I control laser power in tight corners and while accelerating to decrease?
I have a fully nested DXF for files, but no viable CAM solution for this yet.
do you guys have any solutions within budget?
this is for a CO2 laser.
- Thank you received: 5944
25 Mar 2024 23:53 #296788
Replied by tommylight on topic Laser min-max power in CAM
Is the laser controlled by LinuxCNC?
What do you want to do with it? Vector or raster?
Why not use LightBurn?
26 Mar 2024 11:38 #296810
by santy
Replied by santy on topic Laser min-max power in CAM
vector only. lightburn doesnt export gcode does it?
26 Mar 2024 12:13 #296813
See Inkscape, it is open source, free, and can output gcode directly usable in LinuxCNC.
Time to create page: 0.106 seconds
