linuxcncrsh set spindle_override 75 is it bug?
25 Mar 2024 22:57 #296780
by zaxlex
linuxcncrsh set spindle_override 75 is it bug? was created by zaxlex
I have last version LinuxCNC 2.9.2. I add in my hall file it string - loadusr linuxcncrsh --port 5007 --connectpw pw --enablepw pw
and when I connect to linuxcncrsh by telnet I get lost connection after I send set spindle_override 75
it my log:
hello pw k1 1.1
HELLO ACK EMCNETSVR 1.1
set enable pw
set echo off
set estop off
set machine on
[ ALERT ] - Socket got disconnected.
Reason: The remote host closed the connection
[ INFO ] - Connection time: 00:38:58.831
[ INFO ] - Looking up the IP address of server: 192.168.2.3:5007 ...
[ INFO ] - The IP address of 192.168.2.3 has been found. It is: 192.168.2.3
[ INFO ] - Trying to connect to 192.168.2.3:5007 ...
And I must close axis and rerun it to obtain connect.
May be somebody can repeat my test and give me some advice?
it my log:
hello pw k1 1.1
set enable pw
set echo off
set estop off
set machine on
- Thank you received: 5934
25 Mar 2024 23:47 #296787
Replied by tommylight on topic linuxcncrsh set spindle_override 75 is it bug?
Did you try other values for override?
Does the spindle turn on when you sent that command?
26 Mar 2024 19:41 - 26 Mar 2024 19:51 #296828
by zaxlex
Replied by zaxlex on topic linuxcncrsh set spindle_override 75 is it bug?
Yes, I tried other values of override - 25; 50; 100; 1; 0.5; 0.75 - and no luck
today I try send simple "get spindle" without any arguments and get same lost connection.
here it log:
hello pw k1 1.1
set echo off
set enable pw
set estop off
set machine on
get spindle
[ INFO ] - Connection time: 00:06:27.521
and other try with another value of override:
hello pw k1 1.1
set echo off
set enable pw
set estop off
set machine on
set spindle forward
set spindle off
get spindle off
SPINDLE 0 OFF
set spindle forward
get spindle off
SPINDLE 0 FORWARD
set spindle off
get spindle off
SPINDLE 0 OFF
set spindle forward
get spindle off
SPINDLE 0 FORWARD
set spindle increase
get spindle off
SPINDLE 0 FORWARD
set spindle_override 25
[ INFO ] - Connection time: 00:05:32.445
here it log:
Warning: Spoiler!
hello pw k1 1.1
set echo off
set enable pw
set estop off
set machine on
get spindle
Warning: Spoiler!
hello pw k1 1.1
set echo off
set enable pw
set estop off
set machine on
set spindle forward
set spindle off
get spindle off
SPINDLE 0 OFF
set spindle forward
get spindle off
SPINDLE 0 FORWARD
set spindle off
get spindle off
SPINDLE 0 OFF
set spindle forward
get spindle off
SPINDLE 0 FORWARD
get spindle off
SPINDLE 0 FORWARD
Last edit: 26 Mar 2024 19:51 by zaxlex.
Time to create page: 0.078 seconds
