KS100 SERVO DRIVER
28 Mar 2024 15:01 #297004
by RIDO_JIMO
KS100 SERVO DRIVER was created by RIDO_JIMO
Hello,
I bought ks100 servo drivers from AliExpress. The datashets are in Chinese and very soft in information. Does anyone know how can I enable the servos? I will run them in 5V mode step dir way in a 7i96s mesa board.
29 Mar 2024 09:58 #297083
Replied by andypugh on topic KS100 SERVO DRIVER
You could try running the manuals through Google translate?
KS100 turns up many different products, most of which are not servo drives. However searching the web for the manual is probably something you already tried?
05 Apr 2024 18:25 #297659
by RIDO_JIMO
Replied by RIDO_JIMO on topic KS100 SERVO DRIVER
I finally got it!
I found the step per revolution parameter.
However I cannot found how can I manage to make the motor faster. I am using a 1:9 gearbox, I put de step per revolution higher and lower and calculated the stepper scale, but the speed will always be the same, because the stepper scale do that.
How can I manage to make the motor run faster?
Time to create page: 0.099 seconds
