VisMach CAD vs. Joint Origin
- Project_Hopeless
- Topic Author
- Thank you received: 8
30 Mar 2024 17:26 #297222
by Project_Hopeless
VisMach CAD vs. Joint Origin was created by Project_Hopeless
I have a 5-DOF robot Cad model. I exported each link with the same world origin.
In the VisMach script Is there a way to translate the link origin and part independently. For example move the link origin to line up with the joint axis then reposition the cad back to the correct physical position?
30 Mar 2024 17:59 - 30 Mar 2024 18:26 #297223
Replied by Aciera on topic VisMach CAD vs. Joint Origin
You can certainly translate/rotate the stl to the desired position in vismach before attaching it to your model.
However it is much easier if each stl has it's origin in a suitable position when it is imported into vismach.
You'll need to take care of that before you export the stl from the cad. In solidworks for example you can create alternative origins on your part and then choose the appropriate one in the export dialog.
Last edit: 30 Mar 2024 18:26 by Aciera. Reason: clarification
- Project_Hopeless
- Topic Author
31 Mar 2024 00:45 #297253
by Project_Hopeless
Replied by Project_Hopeless on topic VisMach CAD vs. Joint Origin
That is what I'll do.
Another question, what is the difference or use of Rotate vs. Hal-rotate? setting up the Cad.
31 Mar 2024 08:13 #297265
rotate/translate is for use with static values to setup the model.
hal-rotate/-translate is to move the model using hal-pin values.
The following user(s) said Thank You: zz912
