Wiring VFD to MESA 7i96s
17 Apr 2024 16:57 #298469
Replied by PCW on topic Wiring VFD to MESA 7i96s
With that setting what is the output voltage
measured from TB2 pin 22 to TB2 pin 23?
17 Apr 2024 16:59 #298470
by Xinokas
Replied by Xinokas on topic Wiring VFD to MESA 7i96s
I check as well in all show
Component Pins:
Owner Type Dir Value Name
29 bit IN FALSE spindle.0.amp-fault-in
29 bit IN TRUE spindle.0.at-speed <== spindle-at-speed
29 bit OUT FALSE spindle.0.brake ==> spindle-brake
29 bit OUT TRUE spindle.0.forward ==> spindle-cw
29 bit I/O FALSE spindle.0.index-enable <=> spindle-index-enable
29 bit IN FALSE spindle.0.inhibit
29 bit IN FALSE spindle.0.is-oriented
29 bit OUT FALSE spindle.0.locked
29 bit OUT TRUE spindle.0.on ==> spindle-enable
29 bit OUT FALSE spindle.0.orient
29 float OUT 0 spindle.0.orient-angle
29 s32 IN 0 spindle.0.orient-fault
29 s32 OUT 0 spindle.0.orient-mode
29 bit OUT FALSE spindle.0.reverse ==> spindle-ccw
29 float IN 0 spindle.0.revs <== spindle-revs
29 float OUT 83.33333 spindle.0.speed-cmd-rps
29 float IN 0 spindle.0.speed-in <== spindle-vel-fb-rps
29 float OUT 5000 spindle.0.speed-out ==> spindle-vel-cmd-rpm
29 float OUT 5000 spindle.0.speed-out-abs ==> spindle-vel-cmd-rpm-abs
29 float OUT 83.33333 spindle.0.speed-out-rps ==> spindle-vel-cmd-rps
29 float OUT 83.33333 spindle.0.speed-out-rps-abs ==> spindle-vel-cmd-rps-abs
Component Pins:
17 Apr 2024 17:07 #298471
by Xinokas
17 Apr 2024 17:11 #298472
Glad it's working now.
17 Apr 2024 17:30 #298474
by Xinokas
Im sorry and thank you
Time to create page: 0.240 seconds
