Motors do not work together
05 Apr 2024 11:55 #297640
by maxzo
Motors do not work together was created by maxzo
Hello everyone, I am using two motors for x and y, a NEMA 17 and a NEMA 23, each with different drivers (A4988 and TB6600). They are powered by the same external laptop power supply and for logic 'estop out'. One motor functions perfectly fine, while the other does nothing. However, if I unplug one motor from the parallel port, the other motor starts working. I am unsure if this is a PC fault or if I should use separate power supplies. I'm not entirely sure where to start troubleshooting. The controllers are connected only through two power cables and one logic 5V connection, so I don't see how disconnecting one motor could affect the other.
- Thank you received: 5944
09 Apr 2024 11:17 #297854
Replied by tommylight on topic Motors do not work together
Probably wiring issue, most probably missing 0V/gnd.
Pictures of wiring ? Upload here on the forum.
Time to create page: 0.143 seconds
