I pressed the wrong button and i don't know how to fix it
16 Apr 2024 10:20 #298351
by seb88
I pressed the wrong button and i don't know how to fix it was created by seb88
Hi, everything was running fine before. Then I want to have a lock if another display is more suitable for me. I changed from qtdragon to some other one’s .Now linuxcnc didn't start anymore. Does anybody know what I did wrong?
16 Apr 2024 13:23 - 16 Apr 2024 13:23 #298367
Replied by PCW on topic I pressed the wrong button and i don't know how to fix it
You probably want to change this line in your ini file:
DISPLAY=qtvcp qtdragon
To this:
DISPLAY=qtdragon
( Your ini file is /home/seb/linuxcnc/configs/cnc/cnc.ini )
To this:
DISPLAY=qtdragon
Last edit: 16 Apr 2024 13:23 by PCW.
16 Apr 2024 13:26 #298368
by cornholio
Replied by cornholio on topic I pressed the wrong button and i don't know how to fix it
This is your issue
Debug file information:
Note: Using POSIX realtime
./custom.hal:5: parameter or pin 'plasmac.ohmic-sense-off-delay' not found
If the change to the display was all you made change it back to the original.
A bit of advice, back things up before messing around, saves a lot of headaches.
It helps to post the hal & ini files, it's hard to say "this is it, do x & y" without your files.
- Thank you received: 5945
16 Apr 2024 15:12 #298376
Replied by tommylight on topic I pressed the wrong button and i don't know how to fix it
More importantly, what are plasmac pins doing inside a QTDragon config?
Those do not go together, one is for plasma machines, the other for mills.
The following user(s) said Thank You: cornholio
17 Apr 2024 08:43 #298416
by seb88
Replied by seb88 on topic I pressed the wrong button and i don't know how to fix it
Hi, thank you for your help. But changing the name didn't work. I just made a compiled new configuration. I think it is faster and better in the long run too. I'm afraid it will bite me in the … later on. If I don't find every mistake I made.
Time to create page: 0.227 seconds
