Mesa 7i96s Inputs won't work
17 Apr 2024 12:10 #298433
by koernchen
Mesa 7i96s Inputs won't work was created by koernchen
we installed LinuxCNC with a Mesa 7i96s. The Servomotors and the outputs are working fine but none of our imputs are working.
we wired inCom to GND and In00 to +5V but neither the onboard LED or the Halshow shows anything.
Is there anything to try or to do? Is the board dead?
thanks
- Tobias
thanks
- Tobias
17 Apr 2024 13:26 #298438
Replied by PCW on topic Mesa 7i96s Inputs won't work
Are you sure you have input common (P3 pin 12) connected correctly?
An LED/Input might not work if it had been mechanically damaged, thats
the only other thing I can think of.
17 Apr 2024 14:02 #298444
by koernchen
Replied by koernchen on topic Mesa 7i96s Inputs won't work
We measured the voltage between common and in00, it was close to 5V.
Is there any Option to confirm a mechanical damage?
17 Apr 2024 14:30 #298445
Try another input
17 Apr 2024 18:57 #298481
by koernchen
Sadly I tried every input
17 Apr 2024 19:00 #298482
Sounds like your input common connection is not connected
Time to create page: 0.160 seconds
